Team Associated B6 & B6D thread
#8551
I would agree except for the fact that supporting the diff should take a lot less stress than the front wheels took, so that is something we are just gonna have to see. The axle height inserts on the RC10F6 have issues as well which there are a couple easy fixes for, but again those are more inline with the front axle inserts because they take impact during a crash.
#8552
They should just design the waterfall around being able to mount a fan to it.
#8553
Two reasons most likely. One is to keep the spring and nut inside the body, other is to make it easier to swap spur gears without removing the trans from the chassis.
#8554
If they had a kit like the b5m and rear motor conversion kits it maybe worth it. those kits came with a chassis and were a reasonable price.
#8555
When Durango came out with this design in 2012 it was to allow sufficient room for the spur gear when the shocks were mounted in front of the arms. There were no laydown designs back then.
#8556
Here is the link from Associated web site. B6.1D
https://www.teamassociated.com/cars_...ctures_videos/
#8557
#8559
#8560
Flipping the top shaft and slipper nut/ spring moves the weight of those parts more centerline. While the parts don't weigh much, it is rotating mass that was hanging off the side of the car and now it is closer to center.
#8561
looks like you can not use the current slipper lock out from Avid, Schelle, Exotek.
that alone will make everyone buy a new car instead of a conversion kit
there is your answer on the slipper design.
design the car so current B6 owners cant justify an upgrade so they all have to buy a new car, than spend more money to buy upgrades because the current upgrades don't work no more.
I'd say that is a very smart coordination between area 51 and third party parts manufactures!!!
I'm not bitching, just saying. I will be preordering when it comes up
#8562
Just make sure you do a search (Ty Tessman has a good video) on setting up your sway bars. The little grub screws shouldn't be so tight to lock down the sway bar. I've just recently found this out, and properly installed sway bars on my B6 has made it easier to drive. I didn't think they were doing me much good until I figured out I'd installed mine wrong.
#8565
Optimizes dogbone angle when running at low ride height
https://www.teamassociated.com/news/...head_shim_set/
B6.1 with a easier to access gearbox will make it simpler
653Likes
