Team Associated B6 & B6D thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 02-08-2018 | 02:14 PM
  #8551
1/4milecrazy's Avatar
Originally Posted by Wildcat1971
there is a few things I dislike. Diff insert (remember the b5...) Slipper nut prevents a fan being mounted to the chassis...I looks like we might need a new chassis....and a new cmount....might as well sell my car and get a new one, a conversion wont be worth it.
What diff insert did the B5 have? Or are you referring to the front end inserts which look very similar?
I would agree except for the fact that supporting the diff should take a lot less stress than the front wheels took, so that is something we are just gonna have to see. The axle height inserts on the RC10F6 have issues as well which there are a couple easy fixes for, but again those are more inline with the front axle inserts because they take impact during a crash.
1/4milecrazy is offline
Old 02-08-2018 | 02:23 PM
  #8552
They should just design the waterfall around being able to mount a fan to it.
aracefan likes this.
fredswain is offline
Old 02-08-2018 | 02:26 PM
  #8553
Originally Posted by mdwaeracer
So the trans is flipped and laying down? And why are we having the slipper spring on the opposite side?
Two reasons most likely. One is to keep the spring and nut inside the body, other is to make it easier to swap spur gears without removing the trans from the chassis.
MX304 is offline
Old 02-08-2018 | 02:35 PM
  #8554
BRSracing's Avatar
If they had a kit like the b5m and rear motor conversion kits it maybe worth it. those kits came with a chassis and were a reasonable price.
BRSracing is offline
Old 02-08-2018 | 02:44 PM
  #8555
When Durango came out with this design in 2012 it was to allow sufficient room for the spur gear when the shocks were mounted in front of the arms. There were no laydown designs back then.
Lonestar likes this.
Old 02-08-2018 | 03:42 PM
  #8556
TC5Driven's Avatar
Here is the link from Associated web site. B6.1D
https://www.teamassociated.com/cars_...ctures_videos/
rgrg2 likes this.
TC5Driven is offline
Old 02-08-2018 | 03:51 PM
  #8557
olds45512's Avatar
That easy access gear box is awesome!
olds45512 is offline
Old 02-08-2018 | 04:58 PM
  #8558
davidfast, Fearo, aracefan and 1 others like this.
NoEffects6 is offline
Old 02-08-2018 | 05:07 PM
  #8559
Allen Drebi's Avatar
I can still remove the spur gear out of my current B6 with out removing the trany from the chassis !!!!
Allen Drebi is offline
Old 02-08-2018 | 05:12 PM
  #8560
Flipping the top shaft and slipper nut/ spring moves the weight of those parts more centerline. While the parts don't weigh much, it is rotating mass that was hanging off the side of the car and now it is closer to center.
Lonestar and rgrg2 like this.
Chris Brown is offline
Old 02-08-2018 | 05:17 PM
  #8561
looks like you can not use the current slipper lock out from Avid, Schelle, Exotek.
that alone will make everyone buy a new car instead of a conversion kit
there is your answer on the slipper design.
design the car so current B6 owners cant justify an upgrade so they all have to buy a new car, than spend more money to buy upgrades because the current upgrades don't work no more.
I'd say that is a very smart coordination between area 51 and third party parts manufactures!!!
I'm not bitching, just saying. I will be preordering when it comes up
Lonestar and mdwaeracer like this.
Old 02-08-2018 | 05:19 PM
  #8562
RCBuddha's Avatar
R/C Tech Elite Member
Originally Posted by BruceR.
Just make sure you do a search (Ty Tessman has a good video) on setting up your sway bars. The little grub screws shouldn't be so tight to lock down the sway bar. I've just recently found this out, and properly installed sway bars on my B6 has made it easier to drive. I didn't think they were doing me much good until I figured out I'd installed mine wrong.
I should have that video on the first page.
RCBuddha is offline
Old 02-08-2018 | 05:31 PM
  #8563
Rear shocks are different for the B6 vs. B6D
one has less thread?
Old 02-08-2018 | 05:48 PM
  #8564
Forgive me if it's been covered already, but what does changing the differential height affect?
rgrg2 likes this.
Cautrell05 is offline
Old 02-08-2018 | 08:11 PM
  #8565
Pinkz's Avatar
Optimizes dogbone angle when running at low ride height
https://www.teamassociated.com/news/...head_shim_set/
B6.1 with a easier to access gearbox will make it simpler
Pinkz is offline
