Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-03-2017 | 12:01 PM
  #9736
am
What fuel are you using?
am is offline
Old 11-03-2017 | 12:40 PM
  #9737
1evo RRR Driver's Avatar
Then I was using byrons
1evo RRR Driver is offline
Old 11-03-2017 | 05:51 PM
  #9738
Default 4port vs 7port
Can any REAL engine person tell me what's the difference between Novarossi's 4 port and 7port? And why O.S is so powerful with 3 ports?
Old 11-04-2017 | 01:27 AM
  #9739
Because the amount of ports is less important than port and crankshaft timings. The engine is made with the timings.
In case of Novarossi most of the time the amount of ports goes equal up with the price and performance determed by their timings.
Roelof is offline
Old 11-04-2017 | 04:36 AM
  #9740
am
I am not a REAL engine person, but from the messurements i have done for the past 10 years, OS is timing their engines very hard compared to NOVA.
am is offline
Old 11-04-2017 | 05:41 AM
  #9741
Port size, shape, and dwell (timing) are huge factors as well as crank inlet size/dwell and crank bore which also plays a big role.
RCTecher12 is offline
Old 11-04-2017 | 06:17 AM
  #9742
Thanks fellas
Old 11-04-2017 | 09:53 AM
  #9743
SEF's Avatar
SEF
Same here, BTTA was by far my most trusted engine ever, ran 10min stops n went 8-10 gallons , no pinch or rod........I didn't even get that out of my mito, It only lasted thru break-in and 1 race (about 1 gallon). N the bearing took a shit, haven't touched it since n refuse to run any engine with that bearing......��
Thanks. Seems like the Mito is being phased out. I am running Nitropro which has always been great. The bearings in the Mito don’t seem to last.
Lately, I’ve been running the Mantra and it’s been really good in feel and fuel mileage. I hope to get some decent life out of it like my other Novas. I’m coming up on 3 gallons, so it’s broken in and so far it’s running great. We’ll see how long it lasts. I’ll also order a Rolling soon to see how it performs in my truck.
SEF is offline
Old 11-08-2017 | 06:54 PM
  #9744
cczjordan's Avatar
can I put a bonito/keep off piston/sleeve into mito crankcase, even the crankshaft?
cczjordan is offline
Old 11-10-2017 | 02:37 AM
  #9745
I'm using a Bonito piston/sleeve and con rod in my Mito 7. Not the Bonito crankshaft. Seems to be working ok
joeh5088 is offline
Old 11-10-2017 | 03:36 PM
  #9746
cczjordan's Avatar
Anyway will the crankshaft work
Old 11-10-2017 | 04:21 PM
  #9747
The Mito has the offset carb, the crank wouldn't work.
Off-Road Nitro Engines - NOVA - NOVAROSSI WORLD
NitroVein is offline
Old 11-15-2017 | 11:18 AM
  #9748
Is it still possible to purchase TNS modified engines from Neal / thenitroshop?
j321 is offline
Old 11-16-2017 | 12:37 AM
  #9749
Tzicul's Avatar
Go to thenitroshop, select TNS modified and there is a button marked "add to cart". Simple and easy, right?
Tzicul is offline
Old 11-30-2017 | 12:40 PM
  #9750
Lately, I’ve been running the Mantra and it’s been really good in feel and fuel mileage. I hope to get some decent life out of it like my other Novas. I’m coming up on 3 gallons, so it’s broken in and so far it’s running great. We’ll see how long it lasts. I’ll also order a Rolling soon to see how it performs in my truck.[/QUOTE]
My Mito4 broke the rod but my bearings are in tact. I just replaced the sleeve and piston/rod. Still in the process of breaking both Mito4 and 7. How are you liking the Mantra and Rolling (if you got it)?
gilbertfg is offline
