Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 07-07-2017 | 01:05 PM
  #29371
Schs2013's Avatar
so is the M07 that much of a improvement? is it noticeable? since i'm really curios about just the driving/handling characteristics over the M05 from the video's it looks for planted that i have seen.
Schs2013 is offline
Old 07-07-2017 | 01:28 PM
  #29372
ncpantherfan's Avatar
I did some more reading and it looks like the M-07 is using standard length touring car length shocks?
What I find funny is many of the new tc cars are going to mini shocks to lower the cg, which will really mix up and confuse people.
I have a 417, and an evo-6, 5400 mini shocks and the mini big bores at home.
I guess I can take one of each apart and measure the shafts and bodies if that would help anyone.
ncpantherfan is offline
Old 07-07-2017 | 03:35 PM
  #29373
monkeyracing's Avatar
ever mind. Found an answer.
monkeyracing is offline
Old 07-07-2017 | 03:39 PM
  #29374
Toyota Tom's Avatar
removed
Toyota Tom is offline
Old 07-07-2017 | 06:36 PM
  #29375
Core Creations's Avatar
Is that the kit settings for rear toe? Looks like a LOT of toe in.
Originally Posted by shawnh
Heres the first attempt at my wiring.
It didn't go so bad and there is a convenient hole to locate the fan if required.
[IMG][/IMG]
Core Creations is offline
Old 07-07-2017 | 11:19 PM
  #29376
Originally Posted by Scionara05
I know with the m07 out now m05 is so obsolete but has anyone got it to work on black CRC carpet.i run at 360 but we don't run them cause we can't get them to stop flipping no matter the corner and there is some fast guys running them and can't get it to stay rubber down. I tried kit tires but no luck so I'm guessing s type comound would be worse
run a NIMH battery. the extra weight sticks the m05 down nice and good. you might not have as much grunt as a lipo but at least you keep it shiney side up for the whole race
Lunchie is offline
Old 07-08-2017 | 12:15 AM
  #29377
gigaplex's Avatar
Or stick with a LiPo and throw some stick-on weight on the car.
gigaplex is offline
Old 07-08-2017 | 12:43 AM
  #29378
sosidge's Avatar
There is an optical illusion there because the camera is close to the car. But there is more toe-in available on the M-07. Kit build is for 3.2 degrees.
On the topic of shocks, it is a bit odd that Tamiya have decided to base it around an "in-between" shock length that can only be made by combining parts or adding spacers. I have both types available so if (when ) I get an M-07 I will be able to play around to get the best setup.
On the topic of speed, we had two M-07s at our last club meeting. Small carpet track. One racer seemed to make a big step forward compared to his M-05, the other seemed to be a little bit back from where he was previously but he did have some issues with his motor. Both were built entirely as per kit. My M-05 couldn't match the cornerspeed of the M-07s but it was a layout that needed a lot of braking and I am not very good at that.
sosidge is offline
Old 07-08-2017 | 09:20 AM
  #29379
rc_square24's Avatar
Actually in the options page (p.27) of the manual it states the kit uses touring car length dampers, and if using mini length dampers they should be matched with 28mm long piston rods.
I guess I'm one that assumed it uses M-Chassis Dampers. When I was shopping for my FF03 I accidentally bought a set of M-Chassis aluminum dampers, and today when I picked up my M07 kit I bought a set of 42102 TRF Special Dampers intending to use them on the FF03. I guess I'll just extend the rods on the mini dampers
rc_square24 is offline
Old 07-08-2017 | 11:26 AM
  #29380
New retro racer Miglia Mini now available from Phat Bodies for Tamiya M03, 4 and 5
Here - Phat Bodies ? Home
Phat Bodies ? Phat Bodies Miglia Mini
phat_daddy is offline
Old 07-08-2017 | 12:21 PM
  #29381
scirocco14's Avatar
I've gotten the M05 and M06 to work OK on the black carpet, but it's a struggle due to the narrow track/high CG of the Minis. CA on the front sidewalls is a must, but it's not a magic bullet. At some point, it's going to flip if you go too fast through a corner.
I got the cars as low as possible (or legal), using the slicks which are shorter than the treaded radials. That seemed to really help. Also, using as little steering dual rate as I can stand and still make it around the track. Sudden, quick steering inputs can cause a traction roll as well. Smooth, larger radius turns really helps.
The only other solution is to simply slow down a little bit. With lower grip levels, if you go too fast, you'll either push out wide or spin out. With the black carpet, it simply traction rolls (in a blink of an eye). I know it's not the most fun solution.
Mark
scirocco14 is offline
Old 07-08-2017 | 05:30 PM
  #29382
Braking technique and tight radius may allow us to enter corner very fast and not traction roll in black carpet even without CA
https://www.youtube.com/watch?v=wiRSnnZSXwg
Driving Pacman car, braking every corner (but notice car does not slow down).
rccartips is offline
Old 07-08-2017 | 08:36 PM
  #29383
team green's Avatar
Same technique I use to drive Euro Truck.
team green is offline
Old 07-08-2017 | 09:21 PM
  #29384
Scionara05's Avatar
Thanks for all the input I will have to see what works when the track opens back up after the summer break I think end of August.
Thanks for all the replys if anyone has any luck trying any of the info out let the world know please so we can keep the m05 alive lol
Scionara05 is offline
Old 07-09-2017 | 03:22 PM
  #29385
Laguna Bozo's Avatar
After Saturday's practice, there wasn't total Mini Mafia concensus on shock type to use on our new M07's. TC shocks fit perfect. Mini shocks using long shafts also fit, but look a little odd. Either way was capable of high 16's until it got hot which slows lap times a few tenths. S-grips held their grip thru the heat better than Pits. Fred tried Kevin's car and ran as fast as anyone!
OSherman likes this.
Laguna Bozo is offline
