Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-30-2017 | 08:50 PM
  #29341
Schs2013's Avatar
Originally Posted by monkeyracing
I'm thinking about sliding the battery to the left a little to expose the connectors just insid the frame or, mount the ESC on the left and slide the battery right a little. The other option is a super shorty.
The real problem is how to keep it stuck to the car.
idea im throw out there. try 2s made for 1/12 pancar that should open of space issues
*EDIT completely misread that oops sorry.
Schs2013 is offline
Old 07-01-2017 | 01:20 PM
  #29342
Question- will the sealed gear diff from the M07 fit the M05?
Serzoni is offline
Old 07-01-2017 | 02:37 PM
  #29343
monkeyracing's Avatar
R/C Tech Elite Member
No. Totally different. 3Racing, Yeah Racing, TOP and a few others make oil filled gear diffs that work well.
Check tqrcracing.com . Great shop.
monkeyracing is offline
Old 07-01-2017 | 04:00 PM
  #29344
Laguna Bozo's Avatar
Today at Tamiya, Chuck (one of the Mini guru fast guys) did a 16.6 with his new M07. Since most of us struggle to get 17.2's with M05/3, new car is living up to the hype!
OSherman and AngryRog like this.
Laguna Bozo is offline
Old 07-01-2017 | 04:47 PM
  #29345
gigaplex's Avatar
Was that with the 20T pinion?
gigaplex is offline
Old 07-01-2017 | 06:51 PM
  #29346
OSherman's Avatar
It can go faster..
shmit 1 likes this.
OSherman is offline
Old 07-01-2017 | 09:56 PM
  #29347
I think it was his first day...
OSherman likes this.
Old 07-02-2017 | 02:50 AM
  #29348
Steering rack for M07? Is it the same as M05?
So I could use Tamiya (#54191) M-05 Racing Steering Set and Tamiya (#54192) M-05 Steering Link
#edit No. #54764 and #54763
Are the wheel hubs 5mm in the set or any other size?
#edit 5mm stock
Is it short or normal length to the dampers?
NoBrainer is offline
Old 07-02-2017 | 02:59 AM
  #29349
gigaplex's Avatar
No, they're not compatible.
Not sure, but the manual recommends the 5mm alloy ones as an upgrade.
Normal. Short dampers with the long shock end should work fine.
gigaplex is offline
Old 07-02-2017 | 08:53 PM
  #29350
Going through mental checklist of mini parts, th only stuff that is transferable from old to new (besides fasteners, wheel hexes and the like) are the dampers, spur gear and rear axles.
Tony - you mentioned in one of the build vids there was a new ESC on the way. Is this a new HW? Is it really tiny! I've mounted one of my Justocks (old one) and it's a bit of a tight fit.
Old 07-02-2017 | 09:07 PM
  #29351
gigaplex's Avatar
Hobbywing Max10 3300Kv combo. I hear it has near identical performance on the track compared to the previous combo. I think the ESC is actually larger than the older Ezrun that we run, but it's waterproof this time around.
gigaplex is offline
Old 07-03-2017 | 01:04 AM
  #29352
tony gray's Avatar
What gigaplex said...
its bigger, and wont fit in an 07 without dremelling some chassis.
So we're just gonna take the fan off then it's cool
tony gray is offline
Old 07-03-2017 | 10:58 AM
  #29353
Just looked up the footprint size of the ezrun, legacy justock and justock xr10. They're all within 1mm of each other. Might go looking for another solution. Kinda makes me nostalgic for brushed motor setups. The Tekin FXR was so tiny!
Old 07-03-2017 | 11:01 AM
  #29354
OSherman's Avatar
Not sure what chassis you are looking to mount this 'tiny' speedo in.. The M07 has a lot more room for electronics than previous M-chassis. Or maybe the 'openess' of the layout makes it feels as such. Much more efficient chassis design.
OSherman is offline
Old 07-03-2017 | 12:47 PM
  #29355
M07. It's probably just the way the wiring is laid out on the ESC and wriggling it under the reinforcement thingy. I might be looking at it the wrong way too.
