Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 07-08-2017 | 11:26 AM
  #29386
New retro racer Miglia Mini now available from Phat Bodies for Tamiya M03, 4 and 5
Here - Phat Bodies ? Home
Phat Bodies ? Phat Bodies Miglia Mini
phat_daddy is offline
Old 07-08-2017 | 12:21 PM
  #29387
scirocco14's Avatar
Originally Posted by Scionara05
I know with the m07 out now m05 is so obsolete but has anyone got it to work on black CRC carpet.i run at 360 but we don't run them cause we can't get them to stop flipping no matter the corner and there is some fast guys running them and can't get it to stay rubber down. I tried kit tires but no luck so I'm guessing s type comound would be worse
I've gotten the M05 and M06 to work OK on the black carpet, but it's a struggle due to the narrow track/high CG of the Minis. CA on the front sidewalls is a must, but it's not a magic bullet. At some point, it's going to flip if you go too fast through a corner.
I got the cars as low as possible (or legal), using the slicks which are shorter than the treaded radials. That seemed to really help. Also, using as little steering dual rate as I can stand and still make it around the track. Sudden, quick steering inputs can cause a traction roll as well. Smooth, larger radius turns really helps.
The only other solution is to simply slow down a little bit. With lower grip levels, if you go too fast, you'll either push out wide or spin out. With the black carpet, it simply traction rolls (in a blink of an eye). I know it's not the most fun solution.
Mark
scirocco14 is offline
Old 07-08-2017 | 05:30 PM
  #29388
Braking technique and tight radius may allow us to enter corner very fast and not traction roll in black carpet even without CA
https://www.youtube.com/watch?v=wiRSnnZSXwg
Driving Pacman car, braking every corner (but notice car does not slow down).
rccartips is offline
Old 07-08-2017 | 08:36 PM
  #29389
team green's Avatar
Same technique I use to drive Euro Truck.
team green is offline
Old 07-08-2017 | 09:21 PM
  #29390
Scionara05's Avatar
Thanks for all the input I will have to see what works when the track opens back up after the summer break I think end of August.
Thanks for all the replys if anyone has any luck trying any of the info out let the world know please so we can keep the m05 alive lol
Scionara05 is offline
Old 07-09-2017 | 03:22 PM
  #29391
Laguna Bozo's Avatar
After Saturday's practice, there wasn't total Mini Mafia concensus on shock type to use on our new M07's. TC shocks fit perfect. Mini shocks using long shafts also fit, but look a little odd. Either way was capable of high 16's until it got hot which slows lap times a few tenths. S-grips held their grip thru the heat better than Pits. Fred tried Kevin's car and ran as fast as anyone!
OSherman likes this.
Laguna Bozo is offline
Old 07-09-2017 | 05:11 PM
  #29392
monkeyracing's Avatar
R/C Tech Elite Member
I really like this paint scheme. Simple, crude and very mini.
monkeyracing is offline
Old 07-09-2017 | 08:36 PM
  #29393
gigaplex's Avatar
Did anyone try Mini shocks with the Mini shafts, but with the longer shock end?
gigaplex is offline
Old 07-09-2017 | 09:20 PM
  #29394
Yes, with some internal spacing, but the stroke is very limited. Not really a problem under normal running, but if you hit a berm or some such, the shock bottoms out and will send you car on a sky ride.
Old 07-10-2017 | 03:55 PM
  #29395
caltek1's Avatar
Thanks for the feedback regarding the new car. Mine gets a test run this weekend. I fitted normal TRF shocks with the mini springs supplied with the kit. Have you tried and tested the swaybars? I have them. I was going to try soft swaybar rear and hard swaybar front.
Regards
50 Cal
caltek1 is offline
Old 07-10-2017 | 10:50 PM
  #29396
rc_square24's Avatar
Anyone else find the M07 gearbox not as smooth as the M05? Not sure if it's the alignment of the gears or the gears themselves but there seems to be a spot where the mesh is "stuck".
I noticed when I spin the spur gear on the motor mount it's slightly out of round.
It's just something I noticed after completing the top and bottom halves of the gearbox. I'm still building the car so maybe it takes some break-in?
rc_square24 is offline
Old 07-10-2017 | 11:21 PM
  #29397
gigaplex's Avatar
Could just be a bad spur. The 05 spur is compatible so try using one from your other car to verify.
gigaplex is offline
Old 07-11-2017 | 12:23 AM
  #29398
I found the drivetrain sticky as hell after I first assembled it. I'd cleaned stock grease out of the bearings, checked for clearances, interferences, Nada. Turned out one of the 10x15 outdrive bearings was defective. Might be worth checking each bearing out.
Old 07-11-2017 | 07:27 AM
  #29399
iti20090's Avatar
Hi
Been searching the net but no clue so far - is the M05 Mazda MX5 body a straight fit on the M07 in mwb mode? Alway concerned about getting the body low enough. ;-)
Cheers
Dave
This morning at Tamiya, with the new M07, my second lap EVER, was a 16.7. Conditions were ideal for minis, and I was using Pit tires, but this is with a 74 year-old duffer at the helm! Unfortunately, every change I made thru the day from the book settings made things worse, and the temperature was going up quickly, which always raises lap times into the 17's. Except for clipping a mm off each steering cup which allowed some toe-out to keep it going straight down the straightaway, nothing else helped. So, just build it stock, and now everyone is going to have a competitive mini to race...
iti20090 is offline
Old 07-11-2017 | 08:09 AM
  #29400
Any recommendations on shock / piston / oil set up with the big bore mini shock at Tamiya?
madjack is offline
