Palmaris engine thread
#1516
Originally posted by Palmaris Europe
Just home from our last national round at the weekend.
Palmaris Racing did not too bad with 2 team drivers finishing in the Top 10 and another in the B Main.
Want to congratulate my sponsor driver Chris Steele for a demonstration race showing the true capabilities of the BRB sets. He qualified 10th due to bad grip roll and by the end of the first couple of laps was running comfortably in second place behind Mark Green (Serpent Team driver) until the throttle servo gears mangled with 6mins to go.
Mark Green ran a really good race and just seemed to have the car totally dialled in to handle better through the traction rolling giving him that vital edge but it was clear that if the Palmaris Team drivers had got the car better dialled in they would have been unbeatable.
Looking forward to the next race in a few weeks time and should hopefully have the cars dialled better to the track.
I got more result in from the Kyosho cup on Sunday too.
On the 21, one of the BRB user Finished 4th in the A main.
He never raced 1/8 before and to have that result, I think is really good. He put the BRB on a NovaMax crankcase. 0.8mm shims, TF7 plug , 30% odonnel fuel.
Some say he was luck because only 6 car finished the race but too bad the other 4 could not finish with some engine or radio problems.
#1517
congradulations to all the good resullts and hopefully my first 8th scale outing this weekend at ft myers could be as pruductive as those, just getting my new rb c5 from Edward, i know that i will have no problem keeping up, just hopeing that i can get used to the speed and power very quickly ( i love this track though) www.forgass.com hopefully the traction won't be as bad as it was at the winternats. good luck to all
talk to you later with results Peter
#1518
Originally posted by ziggy12345
Hi
Just back from Mendip running the BRB. I was using 0.4mm head clearance and the temp was around 220F The exhaust was not really up to the job and this might explain what I found.
Firstly the low end torque was not as expected and the fuel economy was terrible! I only just made 5 mins and in the 10 min final the second tank only lasted 4:30.
Hi
We already figured this out with one of your other posts regarding needles. 2.5turns out on bottom is too much.
The revs were high and I was one of the fastest on the straight
I will get a better exhaust and see if this helps. I was leaning out the low end but found the car stalling. I thought it was the engine but later found the receiver dead so it was the fail safe cutting in. Maybe the low end needs leaning
There were a few other BRB sets on the track and they were not suffering like i was. My piston set is No 24.
Any suggestions?
Any suggestions?
. Always got time for other people even if they arent running my products.
#1521
Originally posted by kitracer
O NO!!! Is he your sponsored driver..... I am going to get into trouble...
Don't worry, I will stop him from using something else for you...
hehe
hehe
"I will stop him from using something else for you"
I see! He is using STS engine;STS pipe...; We don't have something else,too. lol...
#1523
Originally posted by dino.tw
Hehehe....Ed
That is our sponsored racer.
STS engine & STS pipe.
Hehehe....Ed
Edward
#1524
Originally posted by Top Gun 777
No, Dino. Unfortunately for you, it is only heat sink and pipe is STS, it is Novarossi engine with BRB set in it, but any way, your heat sink was working really good-Congratulation!!!!!
Edward
Edward
#1525
Edward
Edward
..TG you are the best ..BRB set ..WOW
In Italy we use the SPQR set in our STS ..
1Likes
