Return spring for Novarossi .12 >
Like Tree4Likes
  • 1 Post By Serpent-Dan
  • 1 Post By pinoy69racer
  • 2 Post By dan_vector
Old 06-08-2017 | 05:39 AM
mustangkillaz's Avatar
Default Return spring for Novarossi .12
I plan on removing my servo return spring in favor for a engine return spring, what if any are you guys using for the engine? I've found a few, however, they seem geared towards big block engines.
mustangkillaz is offline
Old 06-08-2017 | 08:56 AM
Serpent-Dan's Avatar
Rubber band
Steve_K likes this.
Serpent-Dan is offline
Old 06-08-2017 | 09:42 AM
pinoy69racer's Avatar
balloon
LOW ET likes this.
pinoy69racer is offline
Old 06-08-2017 | 10:16 AM
I was trying to use a real spring, not a rubber band, guys..
Old 06-08-2017 | 09:05 PM
Steve_K's Avatar
Originally Posted by Serpent-Dan
Rubber band
+1
Steve_K is offline
Old 06-09-2017 | 01:17 AM
dan_vector's Avatar
The best thing is the neck of a party balloon. I've used the Zeppin return springs but found these not really strong enough. The party balloon neck doesn't seem to be greatly affected by fuel etc whereas a rubber band seems to perish quickly and break. I've been using balloon necks for probably 20 years with perfect results.
nitrodude and LOW ET like this.
dan_vector is offline
Old 06-09-2017 | 05:23 AM
Most people use hair bands.
Roelof is online now
Old 06-09-2017 | 12:52 PM
~McSmooth~'s Avatar
https://www.amainhobbies.com/gmk-sup...-gmk0104/p7029
~McSmooth~ is offline
Old 06-09-2017 | 02:55 PM
Ok, I'll pick some bands up. If I get a run-a-way, I'm sending you guys the bill..haha. I'd much rather have a metal spring on there. Do you guys have any pics of these set-ups?
Old 06-09-2017 | 05:10 PM
Cant drive's Avatar
Metal springs often bind up the carb and can cause a run away. They also eat away at the carb boot. Use bands.
Cant drive is offline
Old 06-09-2017 | 09:50 PM
JTeamtech is offline
Old 06-10-2017 | 10:09 AM
Thanks. I'll go grab some and give it a second thought.
Old 06-12-2017 | 06:26 PM
avs's Avatar
avs
I like 2 rubber bands, when the first one croaks from use then replace both.
with the KO servo I don't see a need for a really stout return spring but something like Xpert might need a more powerful return spring.
avs is offline
Old 10-05-2017 | 04:11 AM
wkloppen's Avatar
I use 1 rubber band AND a throttle return spring on the linkage. Same function, different implementation. Chance of both failing at the same time is close to zero
wkloppen is offline
