USGT
#6197
#6201
https://www.tqrcracing.com/shop/prod...asp?p_id=11221
but you honestly need the HPI wing for it to be competitive.
#6202
I did enjoy this body:
#6206
My LHS just found these old Matrix Line bodies lying around a warehouse and bought a bunch. Among them are LFA bodies with carbon print. They were 10 bucks so I picked up one and tested it out last night. Kinda hard to see with it being so dark, gotta add a bunch of bright stickers on it, but it handled surprisingly well.
#6207
Is that a standard TC wing used with standard nsx wing mounts?
#6208
hi everyone im starting to run this class my car is a cyclone s with a speedpassion 21.5 and a fdr of 2.43 i would like to know a combination of spur and pinion for a fair top speed, can anyone help me?
#6209
but you'll probably want to shoot for a FDR or 3.9-4.0 for a start. I also think the 2.43 you stated above is the IR (internal ratio) of the chassis. you should be able to find some online charts that will break down what FDRs you'd get for X pinion and Y spur.
but from my experience for the HB TC, TCX and TCXX - you're going to want to use between a 90-100t spur and then the appropriate pinion(s) from there. also, my experience with the SP motors, is they need a little lower FDR to get all the power out of them - i've run a couple before and they are good, but i always had to go to a lower FDR when i ran that motor. i've since switched my last SP to my rally
#6210
i'm confused at the moment
the tires for USGT is still the ones from Gravity, right? Gravity Pro Shop Team Gravity Rc | RC Racing
and you can get them either pre-mounted, or mount your own, right??
6563Likes
