Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 04-10-2017 | 02:14 PM
  #706
vwduud's Avatar
Originally Posted by werner sline
any picture of painted bodies ?
vwduud is offline
Old 04-10-2017 | 02:34 PM
  #707
werner sline's Avatar
looks good !
werner sline is offline
Old 04-11-2017 | 07:48 AM
  #708
suzukipro's Avatar
Anyone else ever tighten their enclosed wheel nuts to the point where the wheel nut bottoms out on the end of the wheel hub? This can inadvertently cause the wheel nut to loosen and over tightening the wheel nut could cause a wheel to come off during a race. I'm going to file off a bit of material from the end of the threaded hubs to see if it helps, but was curious if others have done anything similar to this?
suzukipro is offline
Old 04-11-2017 | 08:13 AM
  #709
Originally Posted by suzukipro
Anyone else ever tighten their enclosed wheel nuts to the point where the wheel nut bottoms out on the end of the hub? This can inadvertently cause the wheel nut to loosen and over tightening the wheel nut could cause a wheel to come off during a race. I'm going to file off a bit of material from the end of the threaded hubs to see if it helps, but was curious if others have done anything similar to this?
That's interesting, I am running those on my .4 without issue. First I've heard of it actually.
ezlight is offline
Old 04-11-2017 | 08:36 AM
  #710
Getting back to setup discussion my kit arrives today. Race at a indoor clay track that's damp clay med/high grip and bumpy.
Kit diff oils? Or are people finding a better setup?
daedalus is offline
Old 04-11-2017 | 08:44 AM
  #711
suzukipro's Avatar
I think the issue develops as the wheel material around the 17mm hex/wheel nut wears out slightly from use. I lost a wheel mid race and this is the only thing that makes sense as to why it came off, wheel tightness was triple checked before it hit the track.
Old 04-11-2017 | 09:02 AM
  #712
bigboyz12000's Avatar
Painted body Tekno EB48.4 - https://www.icloud.com/sharedalbum/#B0iJ0DiRHJFFnyP
bigboyz12000 is offline
Old 04-11-2017 | 11:32 AM
  #713
Derrick87's Avatar
As anyone had an issue with there back adjusting shock collars being really loose? It seems the O rings that go inside are smaller then the front ones no idea why. There extremely loose.
Derrick87 is offline
Old 04-11-2017 | 11:59 AM
  #714
Did you use the wrong ones in the shock cap?
ezlight is offline
Old 04-11-2017 | 12:59 PM
  #715
Originally Posted by bigboyz12000
nice ! impressive radio !
Old 04-11-2017 | 01:06 PM
  #716
Getting through the build... so far, so good... great fit/finish.
This is my first 1/8 scale, so not quite sure what the go-to wheels are. I see EVO by Avid, and various "83mm" wheels that advertise more forward traction. I'm going to be racing on med- to high bite clay. What's the best wheel choice?
Jason B is offline
Old 04-11-2017 | 01:18 PM
  #717
I have the same issue.. fronts are fine.
hyperdive08 is offline
Old 04-11-2017 | 01:23 PM
  #718
On setup sheets it only shows front chassis brace as being checked..Only using one chassis bracke seems a bit risky?
Old 04-11-2017 | 01:37 PM
  #719
Derrick87's Avatar
Yea idk whats up with that....
Old 04-11-2017 | 02:02 PM
  #720
hoyt1967's Avatar
Mine too...wondered the same thing when I was building it. My .3 had a couple that were tight too.
hoyt1967 is offline
