Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 04-17-2018 | 11:44 AM
  #1456
Just picked up a lightly used eb48.4. Wanted to switch over my 8th scales over to Tekno and this buggy makes the final completion. It seems like the only upgrades these need are the Ti coated shock shafts. Am I correct in this thinking? I did notice that the NB48.4 like the front and rear universals. I am itching for our weather in the north east to break so I can get out and put some laps on these things.
ewood810 is offline
Old 04-17-2018 | 11:47 AM
  #1457
EbbTide's Avatar
I think it's just the TiNi shock shafts and of course an aluminum servo horn is always a nice addition when using high torque servos. The aluminum split center diff would be nice too which I bought but mostly just to keep less flex from happening in the center diff area.
EbbTide is offline
Old 04-17-2018 | 12:25 PM
  #1458
Tini shafts are a waste IMHO.
Make sure you have the updated delrin shock cartridge set (Has a shorter hat on the bottom of the shock), Aluminum servo horn, maybe the full aluminum center diff. That's about all the ebuggy needs.
The .4 buggies come with universals. Depending on the track your at, you may want some CVD's for the rear, but leave front as Uni's.
What track are you going to>
ezlight is offline
Old 04-17-2018 | 01:10 PM
  #1459
I dont run at a organized track. I just love to spin laps. Good to know not to wast my money on the shock shafts. Ill look up the delrin shock cartridge. Thanks for the feedback.
ewood810 is offline
Old 04-17-2018 | 01:23 PM
  #1460
Nothing beats a day at the track....Look at it like practice, but with marshals to flip your car over when you get it wrong.
ezlight is offline
Old 04-17-2018 | 02:30 PM
  #1461
ShtLuck's Avatar
so whats the story on these shocks...
is there a fix to keep them from building pressure or no?
ShtLuck is offline
Old 04-18-2018 | 05:42 AM
  #1462
Helps to know how your building them.
I run emulsion shocks, and set to 0 rebound, after several race days, I can fine them having 25% rebound. It's just the nature of the beast.
ezlight is offline
Old 04-18-2018 | 06:54 AM
  #1463
run them emulsion. Bleed them the start of each race day and maybe for the mains.
Honestly my shocks don't build pressure during the course of a race day. Mine build it from elevation changes when I drive to the tracks. I live at or slightly below sea level and in order to get to some of the tracks I'll hit 2000 feet above. My shocks will act like pogo sticks if I don't bleed them.
Bob Barry is offline
Old 04-18-2018 | 07:14 AM
  #1464
hairymuffin's Avatar
The tekno tool is also good to have, helps to put the shock caps on nice and tight
hairymuffin is offline
Old 04-18-2018 | 07:36 AM
  #1465
ShtLuck's Avatar
yeah thats shitty to deal with on race day...
ShtLuck is offline
Old 04-18-2018 | 07:43 AM
  #1466
If I travel a distance, and there's a temp change, I rebuild my shocks when I arrive anyways. but with emulsion shocks, you can cheat by popping the bleeder, and re bleeding the shocks on the vehicle. I'm lazy, and this is my normal way of doing things. LOL
ezlight is offline
Old 04-18-2018 | 07:44 AM
  #1467
EbbTide's Avatar
Isn't the bleeding process stupid simple to do? I have yet to do it on this buggy but I imagine it'd only take a few minutes right?
EbbTide is offline
Old 04-18-2018 | 08:03 AM
  #1468
ShtLuck's Avatar
and everytime you do this you remove oil.
if you remove some oil then you have more air in the shocks causing the issue to continue and get worse as best i can tell.
ShtLuck is offline
Old 04-18-2018 | 08:08 AM
  #1469
it's 4 small 1.5 screws. You don't even have to take the shocks off the car. You're just letting the air pressure inside equalize with outside. You probably won't even get any oil to come out.
Old 04-18-2018 | 08:21 AM
  #1470
Its really up to you,I don’t do it every race. I usually don’t just take my shocks off to be bled. I’m usually changing oil. More so on the nitro car because of temp change through out the day. I’ve never bled them on the car but like bob said, you can.
