Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree128Likes
Xray T4'17
Last edit by:
Print Wikipost
Old 02-28-2017 | 04:12 PM
  #916
Skiddins's Avatar
Originally Posted by TryHard
Absolutely didn't think you were. The only query I have regarding how you've done it, is that it looks like it will affect the bump steer settings. I need to sit down with my car and have a look at it but I have a hunch that the steering links actually sit higher using the floating standoffs....
If you look at the pic, the ackerman balljoints are way above the belt, where most people complain about them rubbing very slightly on the belt.
So they're definitely higher.
I suppose it also depends on how you want your bump steer set as well.
Skiddins is offline
Old 02-28-2017 | 04:14 PM
  #917
JEFFs SC10's Avatar
Go steel with the orange Xray blades... they are literally bullet proof! Even in mod, the orange blades barely wear and last a ridiculously long time, frig knows what they are made from!
thanks, I haven't been running a blade maybe that's my problem.
JEFFs SC10 is offline
Old 03-01-2017 | 12:01 AM
  #918
you can only run blades on the steel/alu outdrives. the stock plastic outdrives are pretty much consumables, so either change them periodically, or upgrade to steel.
perzeus is offline
Old 03-01-2017 | 01:41 AM
  #919
MGU's Avatar
MGU
That's good to know. The plastic outdrives are around 10 € here, while the alu is 20 € and the steel is 30 €. I guess with either of them you will just change blades only. I wonder if this is cheaper in the long run.
MGU is offline
Old 03-01-2017 | 02:49 AM
  #920
+1 for spring steel spool outdrives and orange blades. Black blades are fine too, just need to be replaced a little more often. I replace all blades before any big race anyway.
R Dodge is offline
Old 03-01-2017 | 03:28 AM
  #921
for stock (13.5 blinky) the blades running fine for several runs but needs to be replaced.
i use in front steel outdrives and blades from spec-R, very cheap and need to replace them 2 times in a weekend.
in the back i use the orange version of xray and last forever (almost 6 month`s)
the plastic outdrives getting a lot of space after a couple of runs.
also i think the blades are only usable with the 52mm CVD`s .
moguez is offline
Old 03-01-2017 | 04:03 AM
  #922
Lonestar's Avatar
always set the car up to have max lock, and steer less... if you need more for driving around tight corners, you already have it
My school of thought, too... I wish my fingers would follow though
Lonestar is offline
Old 03-01-2017 | 03:31 PM
  #923
Been working on putting my kit together last few nights. My first X-ray kit and so far really impressed. So much so I I almost want to switch my Offroad stuff as well really impressed with the quality of all the parts.
Only issue so far is I only got two shock springs. Missing a pair. First time I've had missing parts in a kit.
RCJer is offline
Old 03-01-2017 | 08:36 PM
  #924
alecladanga's Avatar
best to go with steel outdrives at front as it would last longer thus, cheaper in the long run. Have used alu outdrives before since steel was hard to get at the hobby shop, still bends (though minimal) with medium/hard impacts and I'm only running 17.5 blinky. Spec R has really strong and good steel outdrives for the xray platform that doesn't even require you to use the blades (if you are looking for a cheaper alternative).
alecladanga is offline
Old 03-02-2017 | 01:33 AM
  #925
MGU's Avatar
MGU
Thank you for the valuable feedback. Since my plastic outdrives are brand new I will run them until they need replacement and then I will go for the steel ones.
MGU is offline
Old 03-02-2017 | 03:41 PM
  #926
Short technical black carpet track gear ratio ?? 3.69 or 4.05
Rcforlife13 is offline
Old 03-02-2017 | 06:14 PM
  #927
Customworksking's Avatar
17 chassis work on the 16car?
Customworksking is offline
Old 03-02-2017 | 06:45 PM
  #928
miller tyme's Avatar
yes, only difference is servo and steering bellcrank is shifted slightly
miller tyme is offline
Old 03-02-2017 | 11:24 PM
  #929
MGU's Avatar
MGU
Originally Posted by R Dodge
Leespeed, xenon and panaracer seem to work well. Those 3 are also the quietest and smoothest brands you will find. If I had to rank them I'd go xenon, panaracer and leespeed but they are very similar and high quality. I have not tried xray pinions yet but have been planning to try them
I received the narrow pinions yesterday and not suprisingly they are a perfect fit together with a xray spur.
  • You can mount them with the narrow end pointing towards the motor,
  • You can still access the grub screw from the top (without removing anything)
  • You have a nice clearing to the belt. (about a millimeter)
MGU is offline
Old 03-03-2017 | 04:57 PM
  #930
JEFFs SC10's Avatar
who makes the narrow pinions? got pics?
I gotta build a new kit for outdoor action.
Does anyone use those foams in the shocks for outdoor?
