Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 02-11-2017 | 05:04 PM
  #28666
monkeyracing's Avatar
The diff is sealed and bearings clean. I'm thinking corner weight is a possible issue. The only things I've messed with lately have been front toe and springs. I'm fairly certain the super tight diff is just making something else into a bigger problem. The car is pulling left on acceleration. Previous corner direction has no effect. I thought it might, so I installed a fresh servo saver.
Practice laps on Tuesday and some wrenching are coming up.
monkeyracing is offline
Old 02-11-2017 | 07:14 PM
  #28667
Originally Posted by monkeyracing
I'm trying to figure out a weird problem. I know we've had this discussion before, but can't find the answer. My M05 is pulling hard to the left on acceleration. This has happened with both my old chassis and new one. I've replaced the servo saver, as well. I've got my steering subtrim set to the right to compensate, but it still hauls left.
I vaguely recall something about the oil filled gear diff possibly being at fault. I've got mine filled with 1M weight fluid. And ideas?
If you use spool or almost spool diff, ofcourse it tend to pull to the left like a real car it called torque steer.. mine is like that too, im using ball diff with 2x0.2mm shims to tighten the diff more, almost like spool
But the pulling is not much soo i don't mind it
And also try to move your esc to the right side, it reduce the pulling issue..
kytr8matic is offline
Old 02-12-2017 | 01:05 AM
  #28668
Schs2013's Avatar
i had that issue race night solved it by playing around with my EXPO on steering and then my Steering rate at 70% or it would doing the same. that was just setting it up on the track for its first time but it may you out.
Schs2013 is offline
Old 02-12-2017 | 02:14 AM
  #28669
sakadachi's Avatar
Check your rear damper height.
If car tracks left on throttle, raise rear right height.
If car tracks right on throttle, raise rear left height.
This is where coilovers become handy vs the spring perch spacers on dampers.
sakadachi is offline
Old 02-13-2017 | 04:25 PM
  #28670
Had to do a little trimming to get the stumpy little Beetle shell on the M04RR.
Old 02-13-2017 | 07:12 PM
  #28671
That's alot of shaving.....
bertrandsv87 is offline
Old 02-13-2017 | 10:17 PM
  #28672
Who knew the middle of an M04 would stick so far out the back when you flipped it around? Cool thing about it: short wheelbase!
Old 02-14-2017 | 03:28 AM
  #28673
sakadachi's Avatar
Looks wrong..!
Old 02-14-2017 | 01:28 PM
  #28674
There is no right and wrong in RC racing, only fast and slow.....
Old 02-14-2017 | 03:02 PM
  #28675
Raman's Avatar
Originally Posted by sakadachi
Looks wrong..!
Lol!
The enthusiast in me says.. That's the wrong generation beetle sitting on that chassis
Then there is the m05 factor... Where all sorts of RWD bodies are being run on a FWD chassis.. So what the hell!
sakadachi likes this.
Raman is offline
Old 02-14-2017 | 05:16 PM
  #28676
You're like a nerdy Yoda.
Old 02-14-2017 | 05:54 PM
  #28677
gigaplex's Avatar
Wouldn't that be something more like this?
"Right or wrong in RC there is not
Fast or slow only there is"
gigaplex is offline
Old 02-15-2017 | 04:48 AM
  #28678
sakadachi's Avatar
So you figure out your tracking issue you had monkeyracing?
Old 02-15-2017 | 06:54 AM
  #28679
Not yet. Won't get any track time until next week.
Old 02-15-2017 | 09:07 PM
  #28680
CW22's Avatar
Hi Guys,
I have 2 boxes YR racing upgrade hop up parts, one is still brand new the extended arm set, the other box is open and come with the steering rack set.
Also come with shocks carbon tower front and rear.
Price $80 shipped for all parts 2 boxes.
CW22 is offline
