Tamiya mini cooper
Guaranteed this question has been answered a gazillion times before so just bare with me. Trying to get some ideas on what people are using to slow down the diff action on gear diff's that I can get locally in my area.
If you're talking about the stock gear diff, then add some Tamiya AW grease, and one or two extra of the large washers.
Spurcheck, simple answer is as per Gigaplex's reply (above). However it's hard to properly answer without more information on what the diffs are that you can get locally. But if you can get a 3Racing or a Spec-R oil filled gear diff then you can tune it with different weight oil...and there's no easy answer then. Oil diffs are tuned to your own style and setup preferences. Anything from 1 million weight (basically locked) down to 2000 weight (not much more than a kit diff with AW grease).
Ofna diff lock lube is best......
Hey guys - Is there an M-05 specific thread? I searched, but didn't find anything in depth. Figured this might be the best thread to search through...Let me know...Thanks!
Does anyone know the size of the smaller bearings in the Tamiya upgraded aluminum steering system
I think they are 630 bearings, Tamiya Part No. 49837 or 42108
