Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 01-11-2017 | 08:12 PM
  #181
Originally Posted by Thunder Trail
Shoot Lutz an email. He will have the fix. They do make some thin locknuts. That would allow you to grind off a couple mm. Should not be dealing with this on a new buggy though.
Why not deal directly with Tekno and call and email them ?
weedsnager is offline
Old 01-11-2017 | 08:38 PM
  #182
EbbTide's Avatar
Well Lutz is a very personable guy from what I've experienced. He took the time to help me get my old Alpha Lutz nitro engine dialed in and he even offered setup tips for my trf801xt even though he had already left Tamiya.
EbbTide is offline
Old 01-11-2017 | 09:32 PM
  #183
Originally Posted by jmcelroy42
No but it will move the hub/wheel further away from there.
My experience was great as well.
Why, because Lutz cares and will make time to help you. I would not hesitate to ask him anything. Very approachable and the best thing that ever happen for Tekno, strong positive influence on RC everywhere. No one among the top factory drivers connects with the RC racer better, NO ONE. His career rides on the RC car he races. He will have the fix and know what if anything will be done about it.
Ryan Lutz
[email protected]
LutzRC, Inc.
Thunder Trail is offline
Old 01-12-2017 | 06:13 AM
  #184
Everyone at the shop excels in customer service and treats each customer as if they are a champion. I'm a huge Lutz fan and agree that he's an amazing resource, but don't hesitate to go directly to Tekno if you need something.
Bob Barry is offline
Old 01-12-2017 | 07:15 AM
  #185
I started building mine last night. I'm having difficulty reaming the rear arms. I have a Hudy 4mm reamer. Each hole individually is fine but the alignment is off when you put the pin all the way through both holes. My reamer wont cut the plastic to clean it out, and of course I'm missing the drill bit I need. Are you guys drilling them? Or is anyone else experiencing this? I've been building cars for 30 years, I've never seen A-arms holes misaligned like this.
greener74 is offline
Old 01-12-2017 | 07:26 AM
  #186
Lutz is using a chainsaw file in a drill. Seems crude, but it works great.
Old 01-12-2017 | 07:28 AM
  #187
EbbTide's Avatar
I had to go with the drill bit because literally every arm reamer was sold out at the time. And I had to wiggle the bit a little in order to correct that slight deformity. And I used compressed air to clean out the holes after I made a drill pass. Took me a few tries for each arm but I eventually got it perfect
EbbTide is offline
Old 01-12-2017 | 07:29 AM
  #188
vwduud's Avatar
Yes. This one:
https://www.lowes.com/pd/Oregon-2-Pa...-Files/1112123
Chuck it up in a drill. Takes less than 30 seconds to get a perfect fit of hinge pin to the arm.
I have the Hudy reamer as well. Hardly touches the Tekno plastic. File is the easiest solution.
vwduud is offline
Old 01-12-2017 | 07:43 AM
  #189
I thought about chucking a file in my drill. Right now my arms are in the freezer hoping to make them hard enough to cut. I'll check the link to the file. We don't have a Lowes, But thanks for the link. This gives me an idea of what I need to do.
Old 01-12-2017 | 07:45 AM
  #190
rcgod's Avatar
Any lawnmower shop or hardware store should have them.
rcgod is offline
Old 01-12-2017 | 07:55 AM
  #191
I'll check on my lunch break, thanks.
Old 01-12-2017 | 08:12 AM
  #192
I used a #19 drill bit on mine. I noticed if you run the drill forward and take it in and out a few times it opens things up nicely. Then if you run the drill in reverse and run the bit in and out a few times it seems to almost polish the inside of the holes. My hinge pins fell right through after doing this to both the front and the rear.
Flippin 416 is offline
Old 01-12-2017 | 09:48 AM
  #193
bigboyz12000's Avatar
Originally Posted by vwduud
Yes. This one:
Going to start building mine tonight. These Chainsaw Files look perfect for the job. Going to stop at Lowe's on the way home and get to building!
bigboyz12000 is offline
Old 01-12-2017 | 09:59 AM
  #194
jmcelroy42's Avatar
I used the Hudy arm reamer on mine, it seemed to take a long time but it worked eventually. Don't try and do one side at a time, you have to push it all the way through. Make sure the slots in the reamer are cleaned out.
I used a #19 drill bit on my .3 and really wasn't happy with how that turned out.
jmcelroy42 is offline
Old 01-12-2017 | 10:37 AM
  #195
Cain's Avatar
If I am reading this right, it looks like the chainsaw file is smaller in diameter than the #19 bit.
Of the two options, which is better?
I have a reamer but it does take a bit to work it through. To be honest, still kind of surprised that this is still something that needs to be done on version 4 of the buggy.
Lastly, what is the diff between the one referenced and this one:
https://www.amazon.com/Oregon-32-Inc.../dp/B000IC26XE
Cain is offline
