Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 04-27-2017 | 02:41 PM
  #931
pballer2777's Avatar
Ok so today I got another set of shock collars. The new collar went nice and snug just like the fronts. The package come 2 collars and 2 orings. So the issue is the collars not the shock bodies or the orings.
pballer2777 is offline
Old 04-27-2017 | 03:01 PM
  #932
Originally Posted by hairymuffin
I put my transponder inside the box
You should put it next to the servo. Cuts a foot off at the finishing line.
Edit...in front of the servo you'll see an empty spot on the chassis.
streetsports is offline
Old 04-27-2017 | 04:29 PM
  #933
Derrick87's Avatar
Is there such a thing as putting your tiers on to tight? If so what are the negative effects of doing so.
Derrick87 is offline
Old 04-27-2017 | 04:51 PM
  #934
EbbTide's Avatar
Do you mean locking the wheel nuts down tight?
EbbTide is offline
Old 04-27-2017 | 05:33 PM
  #935
JoeW's Avatar
It takes some experience wrenching on various things but eventually you know how tight to screw things into plastic before it cracks or strips and how tight to screw different size screws into metal before snapping off the head or stripping it etc. But since there is plastic involved I tighten it until it grabs snugly then go another 1/4 turn or so. You could technically crank it down hard enough to crack the plastic wheel. You want it just right
Derrick87 likes this.
JoeW is offline
Old 04-27-2017 | 06:45 PM
  #936
Stiggosaurus's Avatar
Well I suppose I should check into this thread now--I bought Jason B's EB48.4 this week and it arrived this evening. Jason really hooked me up and I couldn't be happier with it--thanks Jason!
This is my first "competition level" vehicle and I'm coming most recently from a Traxxas Slash 2WD. I've only had a chance to run it up and down the road a few times, but wow is this thing amazing. I'm hoping to get to the track tomorrow evening, but if not then definitely Saturday morning. Can't wait to really see what this thing can do on a proper track.
I'm sure I'll have questions soon enough, but just wanted to pop in and say hi. Will report back some thoughts after its first track outing!
Stiggosaurus is offline
Old 04-28-2017 | 07:15 AM
  #937
Derrick87's Avatar
yes that is what i mean
Old 04-28-2017 | 08:08 AM
  #938
suzukipro's Avatar
I've experienced issues with the enclosed wheel nuts bottoming out against the edge of the hub/axle causing them to loosen. The bigger concern with enclosed wheel nuts is if they become damaged / bent on the end of the wheel nut and give a false impression that the wheel is tight when in reality it is not.
suzukipro is offline
Old 04-28-2017 | 08:19 AM
  #939
EbbTide's Avatar
For 1/8 scale I've always been able to crank the nut down as tight as I needed without any binding. I also use a little loctite on the threads for added security, though I believe the Tekno hubs come with loctite already.
EbbTide is offline
Old 04-28-2017 | 08:51 AM
  #940
Derrick87's Avatar
I was just wondering because iv noticed that the inside of the tire rim seems to be taking off some of the hub carrier like scraping around it. Not sure if thats normal or im just tightening the nuts down to much but to me it doesint seem like i am. Also seems like i have a bit of play in all 4 hubs now "tire wobble" i guess but then again the hubs are plastic so i guess thats normal.
Old 04-28-2017 | 10:21 AM
  #941
suzukipro's Avatar
Depending on the wheel type I've seen wear on the rear wheels / hub carrier too, but it is usually pretty minimal.
Old 04-29-2017 | 07:10 PM
  #942
What bodies will fit the EB48.4? Are the EB48.3 bodies interchangeable? Any better options other than the stock Tekno body?
Old 04-29-2017 | 07:20 PM
  #943
EbbTide's Avatar
You can use 48.3 bodies but there is a section you'll need to cut in order to let the steering rack move freely
EbbTide is offline
Old 04-30-2017 | 10:27 AM
  #944
J 5's Avatar
J 5
Running an extension on the transponder I presume?
J 5 is offline
Old 04-30-2017 | 05:09 PM
  #945
Yes
