1/12 forum
Looking for an carbon axle to replace the metal one on a serpent s120ltr,would like to run the trust bearing assembly with it.Was looking at the irs axle part#2112 but not sure if it will work with the trust bearing,also was told the rc12.5 2 axle will fit,just not sure if the thrust bearing will work with it.,thanks a bunch guys
Having learned from that and having all day Friday at Limburg to play I'm hoping to work from a better starting point.
A good second choice is complete rear axle from zen racing.
Ciao
Ciao
http://muddslidemotorsports.com/1grproaxkibl.html
http://www.discountrcstore.com/RW-Ra...-p/rw64d72.htm
RW racing is what I'm using. Found a US supplier
That's the one
Does anyone have pics of a rear wing mounted on 1/12th body? I've seen where some drivers use a clear wing, is there one made for 1/12th applications or is this something made from excess lexan?
If anyone is using one could they pass along some pics as well as information regarding if they bought it or made it themselves as well as how it is mounted?
Thank you for the help.
Servo question.........does slowing down the servo speed needed..? Steering EXP going to -3 (or lower, delay) and dual rate set to like 60% due to the oversteering no mater how hard of the front tires you use...? I am running magenta front and yellow rear (a typical 12th scale carpet tires setup) and car is un-drivable if I am not doing the servo trim (down).
2991Likes
