Like Tree2991Likes
1/12 forum
Old 10-27-2016 | 10:37 AM
  #45151
TOADYY's Avatar
Originally Posted by Solara
Servo question.........does slowing down the servo speed needed..? Steering EXP going to -3 (or lower, delay) and dual rate set to like 60% due to the oversteering no mater how hard of the front tires you use...? I am running magenta front and yellow rear (a typical 12th scale carpet tires setup) and car is un-drivable if I am not doing the servo trim (down).
Depends on what servo you have. I have a Futaba S9650 and turn down the speed to 75% and have my steering expo at -15. By turning down the servo speed can make the car less twitchy and as Race19s has pointed out, tires will also make the car more drive-able.
TOADYY is offline
Old 10-27-2016 | 10:49 AM
  #45152
I cant find the team prime center shock anywhere. Anybody got any clues?
Bubonic-X is offline
Old 10-27-2016 | 10:58 AM
  #45153
TOADYY's Avatar
Reflex Racing use to have now it's gone from there website. It looks like the only place to get is here:
http://f1shop24.com/shop/product_inf...oducts_id=2004
A little pricey
TOADYY is offline
Old 10-27-2016 | 11:00 AM
  #45154
CristianTabush's Avatar
I Put a few back in stock. I am expecting a re-stock soon, but I have some left that are set aside for our T2 kits.
CristianTabush is offline
Old 10-27-2016 | 12:15 PM
  #45155
I found a Silva shock hope that works well with the RSD conversion kit
Old 10-27-2016 | 01:34 PM
  #45156
chris moore's Avatar
I have been using a silva shock on my RSD conversion with no issues.
chris moore is offline
Old 10-28-2016 | 12:30 AM
  #45157
Grizzbob's Avatar
Super Moderator
Originally Posted by Race19s
IMO with the compounds of tires your running, the Mag will grip more than a yellow. Its just not a good balance of compounds. Get yourself some Green Rears and dont change anything, and I'll bet you'll be closer to driveable.
Agreed, I've tried some Magentas & liked them(but only when doing a bare minimum of doping, less than 1/3 of the fronts), but I was also using pink rears(it's my go-to rear), if my car is going to be less than perfectly balanced, I prefer it to be more stable. And more often, up front I like Purples, might be worth a try to calm the car down. And about expo, yes, you can use it to initially slow the steering down, but to still get full travel, it will actually speed the servo up toward the end of servo travel. I used to use it a lot, but more recently, I decided to train myself to work with full travel & a Linear expo(in other words, no expo at all, set to be linear as possible), first in Virtual RC Pro, & then started doing it in my real car, & now that I've gotten used to it, I'm liking it that way(& I think it's made me faster as well, relying more on my driving than on an adjustment). Something to think about...
Grizzbob is offline
Old 10-28-2016 | 07:59 AM
  #45158
Thanks for the tips...................
I have a JR servo on mine, and I find it not centering very well..........any decent price servo that is good for 12th scale..? Futaba prefer......
Solara is offline
Old 10-28-2016 | 08:18 AM
  #45159
If you have a floating servo mount the savox 1250 is real nice for the price. Has little to no lash as well.
chad508 is offline
Old 10-28-2016 | 08:22 AM
  #45160
TOADYY's Avatar
Futaba S9650 has been my go to servo.
TOADYY is offline
Old 10-28-2016 | 08:46 AM
  #45161
Thank you all....
Solara is offline
Old 10-28-2016 | 10:05 AM
  #45162
Check out the thread wiki. Tons of servo choices in there!
fenton06 is offline
Old 10-28-2016 | 10:20 AM
  #45163
WOW.....thanks, I never thought about that feature until now, thank you.
Solara is offline
Old 10-28-2016 | 12:17 PM
  #45164
I added a bunch of bodies to the wiki, if ya'll could check it out and see if I missed any post up and let me know!
I have a rough idea of which classes the bodies are for, but didn't put anything in the wiki about it since I wasn't positive. Here are my thoughts, let me know if I have anything wrong!!
BA Bodies:
R8C - Lots of steering, stable rear - Superstock / Stock
Black Market - Stable with precise steering, smooth cornering - Mod
Lola B10 - Less rear down force, lots of rotational response. Precise, smooth, and direct handling - Stock
Toyota TS030 - high down force, straight line stability - Mod
PROTOform bodies:
AMR-12 - high downforce - Mod
BMR-12 - high downforce, more stability than AMR-12 - Mod / Superstock
Strakka - reduced downforce - Superstock / Stock
RSD body - More high speed stability than AMR-12 with more low speed steering - Mod / Superstock / Stock
fenton06 is offline
Old 10-29-2016 | 02:34 AM
  #45165
Mirko's Avatar
Maybe you can add some more bodyshells to the wiki?
Blackart 004 Bomb'r
Protoform TR-12
Mon-Tech M12
Blitz T128
Parma PSE Speed 8 HD
And some Servos:
Graupner DES 678 BB MG (7943)
Graupner DES 676 BB (7941)
Graupner DES 587 BB MG (7932)
Blue Bird BMS-A208
Mirko is offline
