Like Tree2991Likes
1/12 forum
Old 10-26-2016 | 01:34 PM
  #45136
Looking for an carbon axle to replace the metal one on a serpent s120ltr,would like to run the trust bearing assembly with it.Was looking at the irs axle part#2112 but not sure if it will work with the trust bearing,also was told the rc12.5 2 axle will fit,just not sure if the thrust bearing will work with it.,thanks a bunch guys
X marksthespot is offline
Old 10-26-2016 | 01:41 PM
  #45137
antlockyer's Avatar
Originally Posted by Skiddins
Eastbourne was weird, it made the cars inconsistent, and I mean like I have never before experienced on that carpet.
We use it at Newbury and you can drive a 1/12 consistently all evening.
I was surprised having run at Rug racers (I was pitted next to Remo BTW) and Newbury in GT and liking it. I also made a couple of big mistakes. Ollie had been saying to me that the car was going to be super safe, so I changed shells and tyres to suit and on the additive just used way too little on the front. If I'd really thought it through and looked at setups from other ETS races it would have been a bit more obvious but I think I was just scared about making it too hard to drive. It took me till heat three to get enough coverage. I also think my shell was slightly off centre and once I'd maxed out on the rear track there was some tyre to body interference. Then my motor died.
Having learned from that and having all day Friday at Limburg to play I'm hoping to work from a better starting point.
antlockyer is offline
Old 10-26-2016 | 02:03 PM
  #45138
TOADYY's Avatar
I have used the IRS axle in my Serpent LTX with no problems and I was using the Slapmaster thrust bearing.
TOADYY is offline
Old 10-26-2016 | 05:02 PM
  #45139
Default Thanks
Thanks TOADYY Just trying to avoid buying something not needed,may be the thrust bearing I have now will work,fingers crossed,trying to race this sunday,might not happen
Old 10-27-2016 | 12:25 AM
  #45140
A good second choice is complete rear axle from zen racing.
Ciao
moraccio is offline
Old 10-27-2016 | 01:14 AM
  #45141
bertottius's Avatar
Everything you need.
http://muddslidemotorsports.com/1grproaxkibl.html
bertottius is offline
Old 10-27-2016 | 05:48 AM
  #45142
chef88's Avatar
Where does one find in stock a 72 tooth 64 pitch spur that takes 1/8 diff balls
Thanks in advance
chef88 is offline
Old 10-27-2016 | 06:06 AM
  #45143
antlockyer's Avatar
Thanks in advance
RW racing is what I'm using. Found a US supplier
http://www.discountrcstore.com/RW-Ra...-p/rw64d72.htm
Old 10-27-2016 | 06:23 AM
  #45144
hanulec's Avatar
Thanks in advance
http://shop.rochercusa.com/index.php...facturer_id=26
hanulec is offline
Old 10-27-2016 | 06:32 AM
  #45145
chef88's Avatar
Thanks!!
That's the one
chef88 is offline
Old 10-27-2016 | 08:23 AM
  #45146
Thanks!!
That's the one
Is that what we need for 17.5 at 180?
Jamie Hanson is offline
Old 10-27-2016 | 08:29 AM
  #45147
Something like that! I'm running a RW 70T there currently.
R Dodge is offline
Old 10-27-2016 | 10:15 AM
  #45148
HK500Pilot's Avatar
Default 1/12th Scale Rear Wing - Pics?
Does anyone have pics of a rear wing mounted on 1/12th body? I've seen where some drivers use a clear wing, is there one made for 1/12th applications or is this something made from excess lexan?
If anyone is using one could they pass along some pics as well as information regarding if they bought it or made it themselves as well as how it is mounted?
Thank you for the help.
HK500Pilot is offline
Old 10-27-2016 | 10:25 AM
  #45149
Servo question.........does slowing down the servo speed needed..? Steering EXP going to -3 (or lower, delay) and dual rate set to like 60% due to the oversteering no mater how hard of the front tires you use...? I am running magenta front and yellow rear (a typical 12th scale carpet tires setup) and car is un-drivable if I am not doing the servo trim (down).
Solara is offline
Old 10-27-2016 | 10:29 AM
  #45150
IMO with the compounds of tires your running, the Mag will grip more than a yellow. Its just not a good balance of compounds. Get yourself some Green Rears and dont change anything, and I'll bet you'll be closer to driveable.
Race19s is offline
