Novarossi engines thread
#5176
Guys, just need an honest opinion, after i tested this combo with 4bbt/4bttwc/keep off 4/keep off 7/paloma,i felt like this pipe is use for economy n not progressive powerband. I think 2096 will give a better progressive powerband. Efra 2058/9886 will wake it up.
Any findings?
Any findings?
#5179
#5180
And which Mito motors, there are many different models.
The 9CL is basically a modified ISON21, not sure if all chosen materials are the same but it is a 14mm crankshaft with a 9 port sleeve, normal long stroke 16.8x16.2 and a standard head.
The Mito7 and Mito9 are based on the Keep-on engine, so a 14.5mm with an xtra long stroke (17.2x15.8), special 14.5 bearing and a lowered head.
The Mito9C and Mito7C are basically based on the older Flash. 14.5mm crankshaft, normal long stroke (16.8x16.2) and if I am right a normal 14.5mm bearing
The Mito 35WC is a re-develloped Mito9C sharing some designs with the 9CL like the new flow channels in the backplate.
Only the timings of the 9CL I have meassured and they are insane for normal consumer Novarossi specs.
#5181
Would you consider that the 9cl have the same performance as any of of the Mitos'? I have not heard of the CL line of .12 and .21 motors till recently and was curious on the performance. I wasn't sure if it was more of a sport motor or a full on racing motor.
#5182
The XL stroke engines, in my opinion, were not Novarossi's finest hour. Thats why the WC engines went back to the 'normal Long Stroke' configuration. The Ielasi Tuned 9CL-WC (the 9CL is an Ielasi Tuned specification) is an epic engine and is quicker than a customer Mito 35WC. Go with with the Ielasi or Mito 35WC engine and you'll be fine.
#5184
I have modified and dyno tested the Mito 35 9 port and its a monster...most powerful .21 I have ever tested....I would put it head to head against any engine in the world ..... If anyone is interested in trying one please message me, if your the right driver we can put you onto my Team and give you the appropriate discounts.... Engine is a monster and possibly makes too much power for racing !
#5188
anyone else having a bad time with engines returned to novarossi.
returned my mito 35 after a replacement conrod failed on the advice of my
contrys distributor saying worst case i would have my old engine back within
a week that was over 2 months ago and still no reply from novarossi
now i know why everyone in the uk runs o.s. engines.
195Likes
