Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 06-08-2016 | 06:16 PM
  #721
Matt Trimmings's Avatar
Originally Posted by Slashn77
I don't have snap chat so any specifics on the new servos as far as speed and torque?
Check reedypower.com, it's all there.
Matt Trimmings is offline
Old 06-08-2016 | 06:43 PM
  #722
Originally Posted by dsms4ever
I looked through the parts compatibility list. and it looks like the bones will work from a b5m in the B6. Just wanted to make sure that if I held onto my mip pucks/ball diff that I could use it in the b6? Thanks. Will the bones work only or will the whole assembled axle work?
You can use them, but same way as if you were to use a B5 AE diff, you have to put shims on the out drives. That's all.
Mxer210 is offline
Old 06-08-2016 | 07:31 PM
  #723
RCBuddha's Avatar
http://www.redrc.net/2016/06/reedy-h...rofile-servos/
RCBuddha is offline
Old 06-08-2016 | 09:38 PM
  #724
Cool thanks Buddha
Slashn77 is offline
Old 06-09-2016 | 01:13 AM
  #725
I have one question, imagine someone buy a B6d, and all necessary parts to convert it to laydow as an option to use when racing in high grip tracks. Will I need 2 bodys?. Maybe I am wrong, but if you cut your body to fit in a B6d trans, when you change to laydown trans it will not be covered by anything because the part of the body to cover the spur and pinnion has been already cutted.
This means we will need two bodys depending what trans we use.
Raulote is offline
Old 06-09-2016 | 02:03 AM
  #726
AZJP's Avatar
No brainer ^^
AZJP is offline
Old 06-09-2016 | 02:12 AM
  #727
Originally Posted by Raulote
I have one question, imagine someone buy a B6d, and all necessary parts to convert it to laydow as an option to use when racing in high grip tracks. Will I need 2 bodys?. Maybe I am wrong, but if you cut your body to fit in a B6d, when you change to laydown trans it will not be covered by anything because the part of the body to cover the spur and pinnion has been already cutted.
Yeah no big deal though
Slashn77 is offline
Old 06-09-2016 | 05:46 AM
  #728
5tone's Avatar
It's already the case with B5M and 3/4 gear gearbox change
5tone is offline
Old 06-09-2016 | 06:06 AM
  #729
Mason's Avatar
Originally Posted by boucher
AE stated from day one it would be offered as an option. Joona was testing with it on what I'd assume to be a low grip track.
part no.'s
91707- 4 gear case
91714- 4 gear motor plate
91717- 26t idler gear
Originally Posted by Jmuck69
It's in the parts section of the B6D page on AE's website.
I found it funny because I thought I was the last guy still running 4 gear on the B5M.
Mason is offline
Old 06-09-2016 | 08:28 AM
  #730
Not exactly, in the B5M you can cut your body to use both trans with only 1 body, but in the B6D, if you cut it, when you install the laydown trans, the spur will not be protected by the body itself, so it will be outside the body and with no cover.
Raulote is offline
Old 06-09-2016 | 09:16 AM
  #731
5tone's Avatar
You're right; and then it's probably illegal...
5tone is offline
Old 06-09-2016 | 09:29 AM
  #732
I agree, probably illegal.
And two bodies needed in this case.
Raulote is offline
Old 06-09-2016 | 11:50 AM
  #733
http://reedypower.com/products/reedy...s/competition/
Chris Reilly is offline
Old 06-09-2016 | 11:51 AM
  #734
Old 06-09-2016 | 12:06 PM
  #735
PW's Avatar
PW
They made a new part number for the b6 ball and gear diff.... But the gear diff parts sold separately all are compatible with the b5m...that's odd, furthermore the b6 ball diff out drives don't list as being compatible, but the cva axles and bones are compatible. A little bit of deduction based reasoning tells me that the b5m ball and gear diff will work perfect in the b6...can anyone prove me wrong?
The B6 diffs are 2mm wider (1mm per side). The new part number for the gear diff includes the needed spacers so you can run the B5 series gear diff in the B6. They are just using the rear axle spacers they made for when using the +4 C/D mounts on the B5. The small spacers are not needed.
PW is offline
