Tamiya TT02 Thread
#916
could be a fun class ...yet another new class!
I am enjoying (slowly) building my TT02
I noticed that the TT02D type S comes w/ a lot of stuff that I don't think the TT02 type S comes w/. The TT02 sype S has the ESC, but ommitted a lot of aluminum parts. I just noticed in one of the bags that my TT02D type S comes w/ metal wheel hex adapters. -so I don't have to use the plastic ones. Lots of blue aluminum parts, graphite shock towers, and oil filled shocks (which are actually pretty nice).
I am building mine as an early 70's Mazda RX3 racer. Stay tuned for photos.
#917
Surprisingly neutral. With the box tires you get understeer on corner entry and a little on power oversteer. But nothing uncontrollable. With standard racing tires the car is on rails, but the fun in a group of racers is much greater with the box tires.
You also can run the car much flatter than a T4 for example. So it looks even more realistic.
#918
I wish we could get a class going in our area. The big problem I've seen are the steering uprights. They are the same as the TT01. The TT01E's are different. I raced in an enduro with TT02 and the steering uprights were constantly breaking. In a school group that I work with the TT01 uprights broke all the time and the TT01E's were better. I would like to see aluminum uprights made legal for any TT02 class.
#919
If so, they are pretty sticky but do wear rather fast. I have used several HPI tires like their x-pattern tires outdoors with success.
Otherwise, you will just need to experiment with a bigger spur and smaller pinion and play around with the motor mount holes until the gear mesh feels right. That is what I do. I almost forgot to mention the YR motor mount as another option. These can be found for around $15 if you search around the web. It is totally adjustable and will give you a much wider range of pinion gear choices.
#920
#921
All I can say about the tt-01d is don't waste your money on all of the aluminium & carbon fibre upgrades. I got one off a guy who spent a small fortune who was gutted to find it didn't hold its value. Also had the XB Coppermix Silvia & didn't notice much difference once balanced with added weights. I had no idea how rubbish this model was until I got something much better but are glad I learnt with the Tamiya first.
#922
#923
I haven't had anything break, so I don't see a need for aluminum and cf bits. How bad must I hit a curb for something to break to render a sturdier part? I'm assuming the stock torque motor won't allow the car to go fast enough to do such damage, so this must be for cars with upgraded motors?
#928
Was thinking about the GTR or the concept NSX.
You know how the NSX handles?
#929
Yeah sorry about that, however the comments about the alloy & carbon fibre are just as valid with the new chassis & I'd quite happily have a Tamiya drifter if it was that or nothing. I was just lucky that a friend was getting rid of something better & could afford it at the time. There's plenty of expensive top quality racing chassis on the market so there's always going to be something much better than a tt-01/tt-02 - just to put it correctly into perspective.
#930
@JD Skyline:
I haven't driven the NSX body yet.
My guess is that the Super GT bodies (GT500 class) come out pretty equal in terms of balance and performance. The Lexus RC-F looked pretty much the same in close racing.
About the breaking issues:
The TT-02 is my first plastic car. And so far it appears to be pretty bulletproof. We had some hard crashes when parking-lot-racing and the car took it without damage. In comparison to my T4'15; I wouldn't be sure that the Xray is tougher...
1387Likes
