Tekno RC EB48.3 Thread
#1486
Ok, about the shocks. I just talked to Amain about the problem I am having with the TiNi shaft on the front. I bought TKR6017T for the front and TKR6061T for the rear. Amain is saying I need part number TKR6004T for the front and TKR6017T for the rear. But I think that would be the parts you use on the 48.2. I ordered the front and rear per the manual option callout. Am I wrong or what? TKR6017T says rear shaft and TKR6061T says X-Long rear shaft. But I am pretty sure that is what I need. Anyone have a contact at Tekno I can ask to be 100% sure?
Does the same issue happen when you use the stock shafts? That'll tell you quickly if it is shaft or something else.
#1487
You are correct. The 48.3 does use the longer shafts, not the shorter shafts like the 48.2 and 48SL do. That would also have nothing to do with an initial bind while the shock is fully extended.
#1488
I was wondering if my servo (2yrs old) is still good enough for the EB48.3 at race level.
I currently have a Hitec 7954sh set with 7.2v (through the xr8+ HW).
It produces a torque of about 400oz.inch and a speed of 0.12s.
Should I keep it until it dies or would I benefit from upgrading ?
I was looking at servos around 0.09s for a 250-300oz.inch thinking of the savox 1267sg
Or even should I go banana and get the 2284sg at 0.65s for the same torque ? I like the aluminium case as the Hitec's is getting pretty beaten up where you screw it to the chassis... (direct mount though as I lost the rubber pads a long time ago).
thanks
thanks
#1489
thanks
thanks
Wouldn't hurt to get a spare as a backup. But at 2 years old, if it isn't giving you problems. Or upgrade to one with better specs, and keep the hitec as your backup....I'm kinda a backup nazi...I hate not having spares.
#1490
thanks
thanks
Personally, I can't run a servo for 2 years in EBuggy. I run a good bit every week and I'm doing good to get a year out of any servo. Usually it's just the gears that get wore out and slop develops.
I would stay away from Savox servos. The motors tend to die in them. I've just started running the Protek servos and so far I'm really impressed with the bang for your buck.
#1491
I also wanted to commend Tekno RC on their customer service. I emailed them about the issue and they got right back to me and sent out 2 new shock bodies (so the colors would match) along with a new bottle of shock fluid and a return label to send in the faulty shock so they could inspect it. Excellent customer service Tekno!! Keep up the good work.
#1493
Just wanted to make another post about what my issue was with the shocks on my new kit. At first I thought it was the TiNi shaft that I bought that was giving me a notchy rough feel when compressing the shocks. So I went home last night and removed the piston from the shaft and worked the shock up and down... Perfectly smooth. Got the same result with the stock shaft. Then I put the piston on the stock shaft and got the notchy feel again. I grabbed a Q-tip and pulled the cotton off one end and ran the stick down inside the body of the shock and the bottom 1/2" of the inside of the body I could feel these grooves. So I held it up to the light and you can see there were these circular grooves inside the body at the bottom. There weren't jagged or anything but they were very shallow. That is what was causing my problem. Anyone else ever experienced this?
#1494
thanks
thanks
#1495
Thanks for the replies
. I'll keep the Hitec then for a while. Actually the Hitec is the remnants of two 7954sh where on one the case busted and gears were worn and the other was going berserk around neutral and had Parkinson elsewhere. I used the working components of both to give me a very good one.
It's good news anyway because I may have a change of plans moneywise and I'm going to go probably for the nb48.3 as well (not enough races in 1/8 ebuggies where I live and can't take the frustration).
I was wondering if the HD power are good servos ?
. I'll keep the Hitec then for a while. Actually the Hitec is the remnants of two 7954sh where on one the case busted and gears were worn and the other was going berserk around neutral and had Parkinson elsewhere. I used the working components of both to give me a very good one.It's good news anyway because I may have a change of plans moneywise and I'm going to go probably for the nb48.3 as well (not enough races in 1/8 ebuggies where I live and can't take the frustration).
#1496
#1497
I need some setup help for my 48.3. Our track has a long high speed strait then a 180 turn. My buggy pushes hard when i try to take the corner. I have 4 steering limiter washers. I run associated diff oils 7-7-5. My setup is pretty close to bornhorst wicked weekend. I can usually get my sct 410.3 rear to break free and drift the corner a little but can't seem to break the buggy rear end free. Track is hard packed, somewhat dusty and watered but drys out quickly. Any suggestions?
#1498
#1500
22Likes
