Like Tree15Likes
Tekin Hotwire App!!
Old 03-02-2016 | 03:10 PM
  #691
Well even skyrc has that option - trouht bluetooth thou but still..
Premium brand like tekin would be obligated to have somethin like this, fot now i bought cheap netbook for this for 30eur, hopefully it will last until tekin comes app with solution for apple or next time this burns out I guess ease of remapping will be my main decission maker or maybe I'll be able to do it with 6r on june, that will also fix me up
janisdaubergs is offline
Old 03-10-2016 | 12:29 PM
  #692
sleddriver's Avatar
https://www.facebook.com/TeamTekin/p...type=3&theater
I'd say iPhone compatibility is coming...
sleddriver is offline
Old 03-10-2016 | 02:42 PM
  #693
mkl
Thats awesome! I hope this comes to market. Just in time for the new DX6r radio too- as soon as I get that radio I will have two ways of tuning the ESC.
mkl is offline
Old 03-15-2016 | 06:32 AM
  #694
Skyrc has wifi- works well on iOS and android
gordonmoney is offline
Old 03-15-2016 | 08:01 AM
  #695
dski's Avatar
Tekin - awesome job on the Android app. I've been making good use of the data logging at the track on my phone.
dski is offline
Old 03-19-2016 | 07:30 PM
  #696
So is anyone using the app successfully on marshmallow? Going to get the galaxy s7 this weekend, tia
mikeinsocal is offline
Old 03-20-2016 | 07:17 PM
  #697
I'm using it on Android 6.. No issues
dgrobe2112 is offline
Old 03-20-2016 | 08:34 PM
  #698
Nice! Thanx for the response
Old 03-21-2016 | 11:31 AM
  #699
Randy_Pike's Avatar
Team Tekin
Yup working fine on the latest 6.01 update on my S6 Edge.
Randy_Pike is offline
Old 03-21-2016 | 07:17 PM
  #700
I'm on a Galaxy S6 running 6.0.1 and I can't connect anymore. My buddie's Note 5 connects with no problem so i know it isn't the Hotwire. I just keep an old tablet in my bag in case I need to use the hotwire at the track.
TimmE is offline
Old 03-26-2016 | 08:55 PM
  #701
i have seen it addressed but not really answered anywhere. can anyone confirm if it does or does not work on the new kindle fire hd's? my 6" fire would be perfect for at the track. if not, what basic tablet or old phone would yall recommend using on the cheap? id like to change out some parameters on the fly on my new rx8 gen 2 setup....
rotor head33 is offline
Old 03-28-2016 | 10:44 AM
  #702
Randy_Pike's Avatar
Team Tekin
It won't work on Kindle's . They have their own version of an "android Os" so to speak.
There are plenty of them listed here:
http://www.teamtekin.com/forum/viewtopic.php?f=40&t=170
There are of course many more that it works on.
Old 04-07-2016 | 08:41 AM
  #703
Ok, I'm at a loss. I can't get either of my rx8 gen2 esc's working with the hotwire android app version 6.11.0 and previous version using a hotwire 2.0 interface. Note: this works perfectly on a PC
These are the devices I've tried and the results:
Samsung Galaxy Tab Pro Running v5.1.1
Used both OTG and regular USB cable
The app starts then I get locked up black screen
Samsung galaxy tab 4
The app does not start after plugging cable into tablet. I connect a battery to the esc and turn it on. The interface powers on but has solid green LED instead of flashing
I get the same above results on a Droid Razr running v4.1.2
Highspeedsentry is offline
Old 04-07-2016 | 11:16 AM
  #704
Randy_Pike's Avatar
Team Tekin
Not all devices have OTG support. A quick test is to take your OTG cable, a USB jump drive and see if you can access the files. For example I generally tell guys to load a video/audio file onto the drive. If you can play the file from the drive, OTG on the device works. If not, your device may not support OTG, you could have a bad OTG or non legitimate cable, etc.
I know for fact that some of the Samsung tablets for example do not support OTG and for whatever reason it's by the size of the screen. Don't ask me why, but most of the time the largest tablets work, and some of the smaller ones do not. Odd I know.
My experience for example on Tab 3, the 7" works, the 8" does not, and the 11" did. Just an example.
The Droid phone lineup often doesn't offer power at the cable of the device so you may need to power on the car once you're plugged in. To test this plug in the Hotwire to the OTG and see if the HW's green LED lights up.
Old 04-07-2016 | 01:31 PM
  #705
I think the device I have the best chance of working with this is my Samsung Galaxy Tab Pro 12.2'' When I plug a flash drive into the OTG cable it brings the drive and it's contents right up.
My Droid Razr is on Tekins list as a known working device. When I plug the hot wire into that I have to plug the LiPo into the ESC and switch it on for the interface to get power. When I do this, I don't get the fast flashing green LED, I just get a solid green LED and it does nothing on the Razr. I'm thinking I might have gotten a bad v2 interface...
I have 2 RX8's I've tried this on with the 250 firmware and the newer beta firmware.
