Like Tree15Likes
Tekin Hotwire App!!
Old 02-01-2018 | 10:49 AM
  #841
Doug T's Avatar
Hi Randy, when I use the hotwire 3.0 bluetooth on multiple RX8 ESC's do I have to bind each ESC to the phone app? Just wondering, haven'd done the second one yet. Thanks Randy hope all is well.
Doug T is offline
Old 02-20-2018 | 03:16 PM
  #842
JevUK's Avatar
Hi All, I'm having trouble setting the current limit.
It's a gen1 rs pro. When I set it to anything from 1 to 9 and save settings when I reload current settings it shows it as off. All the other settings save ok.
It has firmware 223 and I'm using the current hotwire windows software from the Tekin website.
Any help would be much appreciated.
JevUK is offline
Old 02-20-2018 | 03:44 PM
  #843
vivo quevas's Avatar
I think you need to update your software. If I remember correctly the latest software is #228.
vivo quevas is offline
Old 02-20-2018 | 08:23 PM
  #844
258
freebird is offline
Old 02-21-2018 | 05:10 AM
  #845
JevUK's Avatar
Sorry I think it is 228. I don't thing 258 is available for gen1 is it?
There are 2 options available 212 and 228(I'll check this later).
Was this a know issue with some firmware?
JevUK is offline
Old 02-24-2018 | 02:53 PM
  #846
Randy_Pike's Avatar
Team Tekin
No, the HW3 is all that is "bound" to the app/phone.
Randy_Pike is offline
Old 02-24-2018 | 02:54 PM
  #847
Randy_Pike's Avatar
Team Tekin
Check your Hotwire software version:
NO ESC hooked up, launch the pc app, hit the "help" button and list the version here.
Old 02-25-2018 | 06:01 AM
  #848
for the lack of a better place to post this..
tekin RS gen 1... hotwire 2... tekin 17.5 redline gen 1..
radio is Futaba 3PK, with spectrum module... and lipo battery pack
I went from 1/10 carpet pan car to SC5M dirt truck
running a new LIPO 4,000ma battery pack 2 cell.
new futaba S3305 steering servo
issue.... setting is brushless with forward /brake/ delay reverse........
delay into reverse.... what are the rules?
maybe One out of Five it will reverse.
as many times I can not get reverse to go/move truck...
I have latest computer software.. hotwire2 *non bluetooth* is 1 week old and has download 223...
chuck_thehammer is offline
Old 02-26-2018 | 08:35 AM
  #849
With Forward/Brake/Delay Reverse, the esc is looking for the trigger to be at neutral for about 2 seconds before you can use reverse. If you keep pumping the brakes on the radio, it won't go into reverse.
chuck_thehammer likes this.
Krio is offline
Old 02-26-2018 | 09:50 AM
  #850
KRIO,
Thank You.. maybe its that easy.. to fast on the reverse... will try the 2 plus seconds.
Old 02-26-2018 | 12:04 PM
  #851
JevUK's Avatar
Hi Randy, it's 12.40.3
I tried downgrading to 212 but it was the same. I'm back on 223 now.
JevUK is offline
Old 02-26-2018 | 03:37 PM
  #852
Randy_Pike's Avatar
Team Tekin
By default the delay time is set to 1 second, which can feel like forever lol. Also make sure your NW is set to at least 10. If it's too low and you're the driver that "pre loads" the trigger just a tick, it can prevent the esc from seeing neutral for a long enough time. Each time you "try" the 1 second timer resets.
Old 02-26-2018 | 03:38 PM
  #853
Randy_Pike's Avatar
Team Tekin
Ok, that is the latest Hotwire version, so leave it. Is this a Gen1 RS?
Old 02-27-2018 | 03:54 AM
  #854
JevUK's Avatar
Yes Gen1.
For some context. I've not used the feature before but I've just started racing 2wd off road. Would love to turn down power for damp conditions.
JevUK is offline
Old 02-27-2018 | 08:44 AM
  #855
Randy_Pike's Avatar
Team Tekin
Yes Gen1.
The Gen1 RS will stop at 223 software wise. Power can be turned down a few ways; current limiter, epa's, etc.
