New LRP Flow Esc
#1486
Thanks for the reply. The switch was cut off and capped when I bought it. Ran it a couple of seasons with no issues. I have played with the settings before, adjusting to track conditions. I blew it out myself then light with a air compressor to no avail. If the unit is tipped upside down the mode button falls further then the set button, (don't know if that is something) Little stumped with this one. I do have a spare should this have to go to LRP, just thought that there might be something I'm missing.
#1489
No matter what you do with the settings when using the 5.4 firmware in 13.5 boosted you can't make it have a linear feel through the range, if you put it on a stand and test it you will see what I mean, obviously not using full power!
#1491
Yes that is what I am feeling now. I am now running 5.4 with the x20 13.5. So I guess I should just give 4.7 a try this weekend.
#1493
If you pm me your email I can send you the V5 Firmware which is what all the team drivers here seem to use, wish I would of known this when I got mine, have since switched back to Hobbywing but miss the braking feel on the LRP so may give one another go with the right Firmware on
#1498
http://www.mibosport.com/muchmore-fl...ower-capacitor
#1499
Hi guys,
I just tried to flash my flow works team to mod firmware. I left everything alone while it was updating, but it failed part way through. I came back to this message and now it won't reconnect. Is there anything I can try?
#1500
I personally us this one from Muchmore now. It's cheaper and easier to mount to the side of the ESC. The wires are also thicker:
21Likes
