Like Tree21Likes
New LRP Flow Esc
Old 01-23-2016 | 06:59 PM
  #1501
Racing4Evo's Avatar
Originally Posted by cyclonetog
Hi guys,
I just tried to flash my flow works team to mod firmware. I left everything alone while it was updating, but it failed part way through. I came back to this message and now it won't reconnect. Is there anything I can try?
I had this happen and unfortunately nothing worked and I had to send it in to be reflashed.
Racing4Evo is offline
Old 01-23-2016 | 07:01 PM
  #1502
Racing4Evo's Avatar
Originally Posted by N15M0
So any capacitor will do?
Yes. The bigger the capacitor rating the better but you will be fine and hard pressed to notice a big difference so long as you are running 2s Lipo.
Old 02-13-2016 | 01:51 PM
  #1503
MeBeMikey's Avatar
Hey Luke, Three times I tried to do the update. The first time my computer was dead, next the updater failed to open properly and then 3rd time it wouldn't connect at all. I have used it several times to update firmware and never had a problem. I am going to stick with 5.4 as it seems the Universe is telling me to stick with it. I listen to the Universe and I am not happy with its decision.
See yah tomorrow. 5.0 vs 5.4
Mike
Originally Posted by Bar
If you pm me your email I can send you the V5 Firmware which is what all the team drivers here seem to use, wish I would of known this when I got mine, have since switched back to Hobbywing but miss the braking feel on the LRP so may give one another go with the right Firmware on
MeBeMikey is offline
Old 02-14-2016 | 12:25 AM
  #1504
silden's Avatar
Hi,
What is the difference between the 4.7/5.4 and the 5.0 firmware?
Thank you
silden is offline
Old 02-14-2016 | 01:40 AM
  #1505
Explained in the fact sheets when you download them.
Specific firmware for stock, mod, onroad/off etc.
cplus is offline
Old 02-14-2016 | 04:24 AM
  #1506
hello...
what is the best start ratio for flow worksteam + x12 13.5t firmware v5.4 track about 35-40 meter long...and i'm running boosted ....tq
rendangubi is offline
Old 02-14-2016 | 06:58 AM
  #1507
silden's Avatar
I know that 5.4 is stock, 3.8 is off-road and 4.7 is mod.
But what is 5.0.
silden is offline
Old 02-14-2016 | 07:06 AM
  #1508
geeunit1014's Avatar
5.0 is the old stock software. 5.4 is the newer stock software
geeunit1014 is offline
Old 02-16-2016 | 11:10 PM
  #1509
Hi guys, is there any way to know what firmware version is in the speedy as i got it second hand, but I dont have the bridge . thanks in advance
Dual Fuel is offline
Old 02-18-2016 | 01:12 PM
  #1510
Racing4Evo's Avatar
No, I don't know if any way except for the bridge. You can maybe narrow it down to a few firmwares based on how many programming modes you have access to but it gets trickier after that.
Old 02-18-2016 | 01:14 PM
  #1511
Racing4Evo's Avatar
Default New LRP speed control coming soon
I'm hearing there will be a replacement for the LRP Flow released in Summer around July.
Old 02-18-2016 | 02:19 PM
  #1512
swerv512's Avatar
I was just about to pickup my third FWT ESC... maybe i'll wait now.
swerv512 is offline
Old 02-19-2016 | 09:53 AM
  #1513
Hey guys, im using my LRP FLOW with Trinity D4 13.t in blinky.
Any advices on setup ?
piorc is offline
Old 02-19-2016 | 10:05 AM
  #1514
silden's Avatar
I suggest to use the 4.7 "mod" firmware and set it to blinky-mode 5 and 6 to zero. The main difference between the 4.7 and 5.4 firmware are that the brake on the 4.7 feels stronger and the throttle on the 5.4 is a bit more aggressive. I only use the 5.4 for boosted stock and 1/12 mod classes.
I hope this helps.
Denis
silden is offline
Old 02-19-2016 | 11:37 AM
  #1515
Racing4Evo's Avatar
I think you can use 5.4 just change the brake mode from the default setting which is pretty bad IMO. I like the brakes on 4.7 better but 5.4 has much better throttle feel for stock.
I usually run5.4 firmware settings: 5,2,2,6,0,0,0
