Like Tree21Likes
New LRP Flow Esc
Old 08-03-2015 | 08:20 AM
  #1351
Bar
Originally Posted by TryHard
Try dropping the intial drive down (setting 4) lower. Give 1 (3%) a try.
Also try dropping the boost ramp, stock setting is equivalent to 500rpm/° OR 30,000 rpm boost range on the HW (assuming same total boost amount).
Failing all that... try the 4.7 software, as that gives boost and turbo control, and has some lower levels of initial drive too (which I've found even just 1% can make a big difference in how smooth the car is). I get the feeling 5.4 is aimed more at Blinky stock than boosted....
I was looking at running less initial drive, but all that does is make it smoother initially, it's quite strange it just gets to a point probably 1/4 throttle and it goes from being nice and linear to jumping quite drastic. This is very apparent having my hobbywing car running next to it on the bench. I have tried running the boost ramp less, it just has no power then. I see the V5 Firmware seems to be very popular, trying to give that a go when I can get my USB Bridge working
Bar is offline
Old 08-03-2015 | 09:51 PM
  #1352
nova2015's Avatar
Default LRP Flow Programming
As a recent purchaser of a Flow Works ESC, I am generally very happy with it, with one exception. Programming.
I need to get it into 'Boost 0' mode for blinky spec racing but have not been able to. All I get is a solid blue light at neutral. According to instruction, resetting to factory default should enable boost 0, but I'm thinking I am doing it wrong. Manual says to hold set button whilst switching ESC on, but it then goes to initial setup for throttle calibration. Thinking maybe I need to do throttle calibration as well?
Motor used is Tekin Redline Spec 2.
nova2015 is offline
Old 08-03-2015 | 09:58 PM
  #1353
B16A2's Avatar
Your radio must be on and in the neutral position for the blue light to blink so perhaps setting the neutral positions again will help.
B16A2 is offline
Old 08-03-2015 | 10:05 PM
  #1354
nova2015's Avatar
Yep, definitely had TX on, throttle at neutral and trims centred. Is there an easy step by step guide to programming? The brief description on the included manual isn't great. I'm sure it makes perfect sense to someone who is familiar with the process but I couldn't make it happen. ie wasn't sure what mode I was in etc.
nova2015 is offline
Old 08-03-2015 | 10:08 PM
  #1355
B16A2's Avatar
what firmware are you running ?
B16A2 is offline
Old 08-03-2015 | 10:12 PM
  #1356
nova2015's Avatar
It's the last modified firmware, as I had been using this in mod class, V4.7 I believe.
nova2015 is offline
Old 08-03-2015 | 10:13 PM
  #1357
nerdling's Avatar
After completing the factory reset work through the radio calibration steps, ensure if you are using ABS in the transmitter that you disable this first. If the ESC is not blinking check the following:
1. Is the motor turning? set your neutral to stop this.
2. Are the breaks activating? set your neutral so the breaks disengage.
3. What is your Torque Timing (Mode.3) set to? Needs to be 0.
4. What is your Boost Timing (Mode.4) set to? Needs to be 0.
ESC should be blinking after all this has been completed. If not, apply a firmware update and try again, maybe visit the shop you bought the ESC from and get them to assist, some one at your track might also be able to help you out.
nerdling is offline
Old 08-03-2015 | 10:17 PM
  #1358
B16A2's Avatar
Firmware 4.7 defaults to boost and turbo values other than 0
As mentioned above you need to set mode 5,6and 8 to 0 to get blinky mode
Mode 5 = blue led blinking
Mode 6 = red/blu blinking
Mode 8 = red/ble/yel blinking
B16A2 is offline
Old 08-03-2015 | 10:18 PM
  #1359
nova2015's Avatar
Thanks for your suggestions, I will re-check my settings and try again.
I attempted to set modes 3 and 4 to zero, but a large part of the problem was making sense of the programming, not being sure how to get into programming mode, or having a clear indication what mode I was in.
nova2015 is offline
Old 08-03-2015 | 10:19 PM
  #1360
nova2015's Avatar
ok.. so if I was to reinstall the original firmware (1.7) then reset to default, would that set boost zero?
nova2015 is offline
Old 08-03-2015 | 10:20 PM
  #1361
B16A2's Avatar
different firmware revisions have different mode charts, so getting the right firmware mode chart is important
B16A2 is offline
Old 08-03-2015 | 10:22 PM
  #1362
B16A2's Avatar
Install 5.4 and it should default to blinking
I'm not sure if 1.7 existed, factory was 1.4.
5.4 is what you should be running for stock
B16A2 is offline
Old 08-03-2015 | 10:24 PM
  #1363
nova2015's Avatar
Sorry, my mistake, 1.4 is correct, I was referring to the original factory firmware. I will install 5.4, reset and see what happens. Hoping that's all it is as I've been very happy with it thus far.
nova2015 is offline
Old 08-03-2015 | 10:27 PM
  #1364
nerdling's Avatar
Arrggggg!!!!
Can some one remind me how to do a factory reset on a Comet?
(I've asked this in the past but can't find the post).
nerdling is offline
Old 08-03-2015 | 10:30 PM
  #1365
B16A2's Avatar
Is it not the same as the Flow, press and hold the set button while powering on the ESC ?
B16A2 is offline
