Like Tree21Likes
New LRP Flow Esc
Old 02-19-2016 | 12:50 PM
  #1516
silden's Avatar
Originally Posted by Racing4Evo
I think you can use 5.4 just change the brake mode from the default setting which is pretty bad IMO. I like the brakes on 4.7 better but 5.4 has much better throttle feel for stock.
I usually run5.4 firmware settings: 5,2,2,6,0,0,0
Your are right, but the brake is still a bit softer and the maximum amount of drag brake is higher on the 4.7. For the initial punch(minimum throttle) you can set the mode 4 to 9 and it will be the same. Furthermore the initial punch can be in finer increments with 4.7 firmware. 5.4 can be set to a higher initial punch setting as the 4.7(20/27), which can beneficial in 1/12 or at a layout with a lot of 180. On the end you can try both and use the one you like the most.
Have fun
silden is offline
Old 02-19-2016 | 03:43 PM
  #1517
geeunit1014's Avatar
You can run the bd3 brakes on 5.4, it's the second option. Personally I like the X stock brake (default 5.4) better for stock classes, I think it has enough strength and the lo/hi speed brake balance is better. You might find running 1-2 initial brake with the X stock gives you a better brake feeling.
For the d4, I would start with 4.6 fdr and 50* timing. Adjust gearing to temp/track size.
geeunit1014 is offline
Old 02-19-2016 | 07:30 PM
  #1518
tks for advices guys. i race on touring 13.5T blinky. its an small size asphalt track. I will try both
piorc is offline
Old 03-02-2016 | 05:00 AM
  #1519
hello guys...
can i know...vhere can i download firmware v5.0....
cannot find all over internet....
rendangubi is offline
Old 03-02-2016 | 06:06 AM
  #1520
http://site.petitrc.com/reglages/lrp...tsLRPFlow.html
piorc is offline
Old 03-02-2016 | 07:22 AM
  #1521
Originally Posted by rendangubi
hello guys...
tq piorc for help....this is the link...
http://site.petitrc.com/reglages/lrp...w/Flow_v50.zip
Old 03-02-2016 | 07:31 AM
  #1522
why firmware v5.4 dont have turbo....is it automatic calculated or they just disabled it....
or turbo have bad effect to motor...tq all
Old 03-02-2016 | 04:49 PM
  #1523
silden's Avatar
There is not turbo function available in the 5.4. In Stock you whant more overall, therefore you put at lot of boost on it. But there will be no room left for any turbo.
the 5.4 allows al lower initial drive and boost values as the 5.0.
I hope this isn't even information helps.
silden is offline
Old 03-06-2016 | 06:31 PM
  #1524
I own (2) LRP flows and x-20 motors. I want the V 1.5 software so that I can have reverse. I own a mac and have read there are issues when using a mac to update software ? I have called LRP N AMERICA ( California) 2 times and left messages. with no call back. I have sent (2) e-mails, with NO REPLIES 3 weeks ago. I have a local LRP TEAM driver who said they cannot help me with that either. I have never before dealt with a company with no regard to customer support as this in my 20 yrs of playing with toy cars. The product is nice, however this I wish I could say lack of support, but I have to call it zero help from LRP is disappointing . I have no problem sending them in and paying. I have checked the website for info on how to do this. If it is there I must have missed it. I would of thought a return phone call or a return e-mail would be reasonable with in 3 weeks ?
miket3 is offline
Old 03-06-2016 | 06:56 PM
  #1525
Nat Maniac's Avatar
I should show you the (slow and painful) email conversation I had with the customer support team in Germany.... took weeks for them to confirm that their software update program does not work on OSX...talk about stuck in the 1980's!
Normally when I think of German companies I think, efficient, reliable market leaders...not in this case unfortunately.
Perhaps someone can download the software to a laptop and bring it to the track for you, then you can just use your bridge to update.
All the best
Nat Maniac is offline
Old 03-06-2016 | 08:53 PM
  #1526
RedBullFiXX's Avatar
Fortunately I've never had issues with LRP products either, but the support side is probably driving racers to other brands...
RedBullFiXX is offline
Old 03-06-2016 | 09:29 PM
  #1527
silden's Avatar
Unfortunately the firmware updater wasn't updated since 2011. I thied it on all of my macs and it only worked on the one with Lion installed. I contacted my team-manager at LRP America to assist us with this issue.
silden is offline
Old 03-08-2016 | 11:49 PM
  #1528
I decided to go back to using my flow again. I wanted to make sure I was running the v4.7 software, hooked up the bridge to my mac, attempted to open up the updater.........
Realtek is offline
Old 03-09-2016 | 12:20 AM
  #1529
Nat Maniac's Avatar
https://www.youtube.com/watch?v=IN2bSkSMMzY
Old 03-11-2016 | 06:21 PM
  #1530
flionbrian's Avatar
Default Software update on a mac help?
Hey guys,
I bought a Flow Competition ESC and a USB Bridge spec 2. I use an imac. I downloaded the firmware driver from the LRP site okay. When I click on the LRP Firmware Update Tool 2.0.7 icon to install the software, all I get is a pop up message that says "LPR Firmware Update Tool 2.0.7" is damaged and can't be opened. You should eject the disk image. I have tried to download it 3 times from scratch deleting the previous download first but still got the same result.
any tips?
flionbrian is offline
