Like Tree21Likes
New LRP Flow Esc
Old 11-24-2015 | 09:39 AM
  #1456
gearhead_22's Avatar
Originally Posted by RedBullFiXX
Yes
4.5 X12, 27.5 *
No boost
Esc temp, 150
Motor temp 105
96x26
in other words you are running blinky
gearhead_22 is offline
Old 11-24-2015 | 09:48 AM
  #1457
RedBullFiXX's Avatar
yes, small track, no need for boost
with boost at a larger track like IIC, i used a fan on the esc
RedBullFiXX is offline
Old 11-24-2015 | 10:00 AM
  #1458
thanks im on a small track.
Old 11-24-2015 | 10:10 AM
  #1459
Cool
Alos, an X12 4.5 is significantly faster than a 5.5, surprisingly so
Old 11-24-2015 | 10:17 AM
  #1460
i have the X20 5.5 and fast enough for my first time running mod.
Old 12-14-2015 | 06:32 AM
  #1461
Somehow i blew my speedy turning my car on after a few months on the shelf...
Now i'm considering whether to get a new LRP Flow WT or is there a new one coming out soon...
Anybody got any news?
Zhangesh is offline
Old 12-15-2015 | 03:50 PM
  #1462
Since I use Windows 10 on my notebook the LRP softer updater V2.07 doesn't work. Any suggestion to solve this problem?
Wascheck is offline
Old 12-16-2015 | 03:44 AM
  #1463
julius_makewar's Avatar
Can anyone help please. I have two Flow Comp ESC's do the same thing now. Switch them on, receiver gets power and servo works but nothing from the ESC. Just the Blue LED blinking at me. Buttons do nothing. I have updated software etc. But the simple fact is the damn thing sit the blinking at me with no working buttons.
julius_makewar is offline
Old 12-16-2015 | 04:45 AM
  #1464
Have you done factory reset after the software update?
push and hold the SET Button, than power on the ESC.
mailman81 is offline
Old 12-16-2015 | 04:59 AM
  #1465
That must do the trick.
Govert is offline
Old 12-16-2015 | 07:51 AM
  #1466
Factory reset cannot be done because the buttons are not working any more. Just the Blue led blinks. Two ESC's doing exactly the same thing.
Old 12-16-2015 | 08:23 AM
  #1467
I wonder if you have tried it the way mailman81 says:
-Turn tranmitter on (safety measure).
-Connect lipo to esc.
-Press and hold SET button, then switch on the esc while still pressing down the set button. Keep holding down the set button for 2 seconds and release. Do this (resetting procedure) 3 times, just to be sure you are actually resetting it.
So FIRST press and hold SET button. Only that will work.
Without resetting the buttons never work.
Govert is offline
Old 12-16-2015 | 09:23 AM
  #1468
To use an LRP esc without buttons is like trying to drive a car without keys, unless you have that push button type of new car, but without the button...
If you open the case you can probably access the buttons for a reset ?
Old 12-16-2015 | 09:31 AM
  #1469
If he's missing the plastic buttons, he can still reach the button on the pcb with a 1.5mm hex
Govert is offline
Old 12-16-2015 | 10:55 AM
  #1470
silden's Avatar
Hi Guys,
It sounds like the Speedos are in brick mode.
Have you connected a motor to the speedos, powerwires and Sensor?
If not than connect a motor. In case a motor is connected try a different sensorwire.
If this isn't helping, open the case and clean all the debits out of it.
And as a last step you can call LRP for service.
Denis
silden is offline
