Like Tree21Likes
New LRP Flow Esc
Old 06-05-2015 | 07:51 PM
  #1306
Ivan Dickson's Avatar
Default Brushless LRP X20 Motor 17.5
For sale LRP X20 17.5 motor only has a couple practice runs, never been in
a race...just like new. Price $50 Free Shipping US only.
Only accept Paypal for payment.
Ivan Dickson is offline
Old 06-10-2015 | 10:33 PM
  #1307
Might want to post this in the for sale thread . my friend .. Excellant motor ..
mb racer is offline
Old 06-11-2015 | 02:06 AM
  #1308
Originally Posted by radek
Has someone successfully tried pairing the flow with a sonic reedy mach 2?
Considering buying one, but after experiencing the flow not getting along very well with both a speedpassion 3.0 and a sky ares pro motor, I'd appreciate any advice.
See the issue I had matching these two. Nothing I did resolved it. Even went as far as emailing the pro's and pro themselves and non could figure it out. Speedo even got sent back with the motor and both were fine. In the end I gave up ran an lrp x20 and it worked perfectly. Very fickle Speedo is the Flow.
https://youtu.be/sM9eYB6hVF8
Mi4cxl is offline
Old 06-16-2015 | 01:42 AM
  #1309
Has anyone come across this issue:
Flow will not program, calibrate or anything. It just turns on and issues a solid blue light. The ESC works and spins the motor. It also took the new firmware package I did the other night. But nothing can be done with the ESC mode and set buttons to customize the ESC.
Factory reset it (No idea if it works because it's just a solid blue no matter what I do)
Anyone?
SC Shaun is offline
Old 06-16-2015 | 06:36 AM
  #1310
RedBullFiXX's Avatar
Anyone?
Have you tried re-flashing firmware update, then factory reset
RedBullFiXX is offline
Old 06-16-2015 | 02:53 PM
  #1311
No9's Avatar
No9
Hi guys need some help,i have a flow comp and orion vst2 13.5.
They are near new and have been great but i tried to time up the motor by 5deg from stock and it coggs,tried it with my tekin and it runs fine.any ideas.
I tried 3 sensor cables and both sensor ports on the motor and still the same.
Thanks in advance.
No9 is offline
Old 06-16-2015 | 06:36 PM
  #1312
jdawg81's Avatar
Default Need help with menu settings with 5.4 firmware
I upgraded to the 5.4 firmware but now I can't figure out what the flashing of the LED's mean as they no longer flash according to the what the manual shows. With the ESC in blinky mode, I wrote down how the LED flashes and counted the maximum values available for each mode.
Here's how the Mode LED's now flash with the 5.4 firmware:
Mode 1
Mode LED: Red LED flashes
Set LED: Max of 10 values, Default setting is off
Mode 2
MODE LED: Red LED flashes quickly
Set LED: Max of 2 values, Default setting is off
Mode 3
MODE Led: Red LED flashes with slight pause in between each flash
Set LED: Max of 10 values, Default is off
Mode 4
Mode LED: Yellow LED flashes
Set LED: Max of 10 values, Default is 5
Mode 5
Mode LED: Blue LED flashes
Set LED: Max of 5 values, Default setting is off
Mode 6
Mode LED: Red and Blue LED flash simultaneously
Mode 7
Mode LED: Red and Yellow LED flash simultaneously
Set LED: Max of 1 value, Default is off
jdawg81 is offline
Old 06-16-2015 | 06:50 PM
  #1313
B16A2's Avatar
The new firmware comes with a new pdf with information on what the flashing LED's mean. More parameters have been added.
B16A2 is offline
Old 06-16-2015 | 07:56 PM
  #1314
Mode 1
Mode 2
Mode 3
Mode 4
Mode 5
Mode 6
Mode 7
http://www.lrp-americastore.com/cont...apGuide-EN.pdf
nitro_cortex is offline
Old 06-16-2015 | 08:42 PM
  #1315
jdawg81's Avatar
Originally Posted by nitro_cortex
Thanks for the help, I did not realize the firmware came with updated instructions as I had someone else do the upgrade for me.
jdawg81 is offline
Old 06-18-2015 | 04:52 AM
  #1316
I got to see two of volkers cars up close at AOC today (and I took him out in practice at one point ) and his one of his speedies (still labelled flow works) is definitely not the same as the one I run.
He said towards end of the year for a new ESC most likely.
cplus is offline
Old 06-18-2015 | 05:28 AM
  #1317
what do you mean by its definitely not the same? cosmetically? details pls
Zhangesh is offline
Old 06-18-2015 | 09:55 AM
  #1318
chasingthepack's Avatar
a new esc is in the works,why else would they be practically giving them away,if you bought a do6 you were given an lrp flow works with it,still like mine
chasingthepack is offline
Old 06-19-2015 | 04:09 AM
  #1319
I spotted the heat sink first. It's different. Wider fins and different finish. Rest of case looked the same pretty much.
He then told me the guts is all new also, as is the firmware.
cplus is offline
Old 06-19-2015 | 04:14 AM
  #1320
Ray Kindstrom's Avatar
Setup box instead of flashing lights for adjustments?
Ray Kindstrom is offline
