Hobbywing Justock esc
#181
One of the biggest issues running this esc without a booster is the loss of servo speed. If you are running a road course your servo is only running on battery voltage. With a booster it will run at 5 or 6 volts depending on the model/brand. That is also why the amp rating of the booster is important. On another note, the older/larger AMB transponders need 5v to operate reliably. You don't want to miss being counted.
#182
#184
Tom
#185
Correct the low voltage issue is a 1s issue only. Newer transponders work at lower voltages so they don't have a problem. The servo is still slower than when at 6v.
#186
Tom
( not sure I buy it, but I've seen more problems with the newer than the old. At least here.)
#187
The only problem I ever had was with the older. I had the booster fail in a HW V2.1 1s and I missed laps late in the run. I will guarantee that I was below 4 volts because that was a WGT running a 13.5 and it was at the very end. I am also sure it was well above 3. Transponder was placed on the chassis and between the front wheels. I am talking the really old 1" x 3/4" red units (minimum 15 years old).
#188
#189
Question about "Punch" mode setting. I believe this only comes in at the start of a race - i.e. car has been sitting idle for some time waiting for the horn and punch mode is activated?
Have I got this right or is punch mode active at all times, kind of like an expo throttle setting?
Bruce
Bruce
#190
Bruce
Bruce
#191
Bruce
Bruce
hope this helps
idbdoug
#194
This ESC is very smooth.
But I found that punch is little less than my V3.1, but XR10 brake feels a lot stronger.
On my V3.1, I had to adjust expo for throttle to -70% expo to make it calm.
But with my XR10, I seemed to be able to dive it with 0% expo.
Mine doesn't get hot at all.
It could be due to the changes I made for V3.1.
But I think I am still gonna stick with V3.1, cuz somwhow, I think my servo is slower with XR10, but this could be just in my head, or could be that the track condition was extremely high bite when I tested my XR10. It never glitched though.
4Likes
