Hobbywing Justock esc
#196
So a booster isnt absolutely necessary with these justocks? Im thinking of buying another one for 13.5t/17.5t 1/12th 1S.
#198
I will let you guys know about a problem I had a few weeks ago with a JustStock and no booster. I was running oval, 17.5 1 cell. The JustStock is the spec esc. I have run this combo for about a year and this started. On corner exit, the car would continue to turn left after about 3 minutes of running. It would straighten out if I let off of the trigger. I run a Spektrum system and I found out they like at least 3.5 volts to the receiver. On a bench test with a Thor chassis dyno I discovered that the voltage at the receiver would drop about a half volt when the trigger was pulled. Without a booster you are looking at battery voltage. At 40 laps the battery is down to just under 4 volts so you can see where I ran into the issue. What was happening was receiver brown out. The esc still works but the signals from the receiver can go away briefly. I will now run a booster.
#199
I also had problems with my car not turning properly in some corners running a XR-10 without a booster. I also had much slower starts than I am acustom to at the start of the mains. I got the HW booster and the problem was solved. Yes you can run the HW Just stock and XR-10 without a booster but after awhile you notice something is just a little off. A 24.00 booster is not that much to pay to keep the speed in the servo and AMB lap counter!
#202
i was looking into an esc for my b5m i was planning on a reedy combo with the 800z but someone sugested the justock not sure which model but how does it compare to the 800z?
#205
Does the justock club spec come with a senser harness
#206
#210
Latest upgrade
Hi all.
Does anyone know what the newest upgrade is. V1_509 or v3_508.
Cheers
Cheers
