Hobbywing Justock esc >
Like Tree4Likes
Old 01-10-2016 | 01:55 AM
  #166
Can the timing on the motor still be adjusted with this ESC?
performula is offline
Old 01-10-2016 | 04:40 AM
  #167
idbdoug's Avatar
Yes the physical timing can be set on motor endbell, no you can't set any electronic timing via esc
idbdoug
idbdoug is offline
Old 01-10-2016 | 06:50 PM
  #168
nf_ekt's Avatar
Originally Posted by s1a1om
I just saw someone on the 1/12 thread post that they run this esc with a 1s battery, but nothing else I can find suggests this is possible. Can someone please let me know if this does indeed work?
I run a cheap voltage booster with mine, though plenty of guys are getting by with just the esc itself. They are probably the best budget esc's ever released.
nf_ekt is offline
Old 01-10-2016 | 08:28 PM
  #169
I just ran this esc at TQ . in 17.5 class no booster or reciever pak .. tq/win ... It has always ran good for me .. If running 13.5 i would suggest running a booster ..
mb racer is offline
Old 01-10-2016 | 11:27 PM
  #170
vabroom's Avatar
what voltage booster are you using for TC 13.5?
vabroom is offline
Old 01-11-2016 | 01:29 AM
  #171
Grizzbob's Avatar
Super Moderator
You don't need one in a TC, assuming you're using 2s batteries. There's only a chance of needing one if you're using a 1s battery, where its nominal voltage might drop below the ESC's needs(& as mb racer said, even then it's not always needed)....
Grizzbob is offline
Old 01-11-2016 | 06:12 AM
  #172
idbdoug's Avatar
https://cdn.shopify.com/s/files/1/01...DC-DC.pdf?2317
Here are HW's official procecures, just follow direction for esc with built in BEC
idbdoug
idbdoug is offline
Old 01-12-2016 | 01:13 PM
  #173
I was running this esc with a savox 1251mg servo. During the race I experienced a brown out; like it just died for a minute. Then it came back to life. I was racing mini.
Is there a known issue with Savox servos and this esc? I read in a few places hobbywing products had these problems.
It could be a switch that was off; but does this servo/esc theory have any merrit?
irvinew is offline
Old 01-12-2016 | 01:35 PM
  #174
JayL's Avatar
It's a known issue with Savox servos in general, some work perfect others cause brownouts, same servo model.....
JayL is offline
Old 01-12-2016 | 03:24 PM
  #175
I use the same exact same esc/servo combo and haven't had any problems in the past 3 1/2 months of racing. I have heard, however, about people having problems with savox at my track. I guess it's just hit or miss.
speed_dmon is offline
Old 01-13-2016 | 08:58 AM
  #176
Anybody know what the Initial Brake Force setting (#7) does? Is it like an ABS function?
It looks like there is an error in the instruction sheet as it describes the max reverse force twice.
Bruce
belewis01 is offline
Old 01-13-2016 | 09:14 AM
  #177
theproffesor's Avatar
It means the amount of braking force applied when you first touch the brakes. Ie if you set it at 20% then your brake pressure will start at 20%. I set mine equal to drag brake
theproffesor is offline
Old 01-13-2016 | 03:45 PM
  #178
Thanks - make sense now
Bruce
Old 01-13-2016 | 11:52 PM
  #179
sorry about that .. I was running 17.5 / 13.5 12th scale ... If u do need a booster for either , try novak , Ive ran them in the past with no problems ..
mb racer is offline
Old 01-14-2016 | 04:57 AM
  #180
One of the biggest issues running this esc without a booster is the loss of servo speed. If you are running a road course your servo is only running on battery voltage. With a booster it will run at 5 or 6 volts depending on the model/brand. That is also why the amp rating of the booster is important. On another note, the older/larger AMB transponders need 5v to operate reliably. You don't want to miss being counted.
old_dude is offline
