Argus USA Engines Thread
#1997
Did a little practice video after last months Mnrc Rd. 6. The track grooved up awesome but didnt wear tires. Ran M4 Lockdowns and ran them 1/2 hr in the B and 1/2 hour in the A.
For an engine I was trying to tame down the R8 for my needs. I inserted the crank, opened up crank timing and raised the sleeve a bit. I love this powerband and outran pretty much everything down the straight. Sorry the vid isnt the best, my nephew doesnt have much experience filming.
Rex
https://www.youtube.com/watch?v=9Nzc2rK-nV4
Rex
#1998
Ran at Fear Farm for the first time Saturday night. Made the A main in open buggy with my R8. Motor had enough power for most of the jumps but think I need to repipe it. Currently running a Go 2072 I had sitting on the shelf. Think it's better for high end speeds. Running a dynamite 053 in my Truggy on a modified R8 and it's a monster combo with no power issues. Anyone have any other pipe recommendations for a stock R8 for more bottom end? Both my R8's idle great and have never flamed out!
#1999
I still wouldn't mind getting a little more bottom end from my non modified R8 for buggy, but think I found out why I seemed to lack power compared to running at my home track. Ran a onroad race in LA last month and won a gallon of fuel. It's 25% onroad fuel with less nitro and more caster than I usually run in my 30% offroad fuel. Should I pull one head shim and still repipe? Fear farm has some super big jumps that are close together, so low end power is crucial. Maybe I should bump up to 7mm restrictor too?
#2000
I found the 7mm restrictor to give considerably more power than 6.5mm with barely noticeable less runtime (of course, these is based on my testing, on my home track). So I think it's a safe bet to go to 7mm. Also, try the 2090 pipe, it's the allround best pipe for this engine in my opinion.
#2001
Rex
#2003
Rex
Rex
#2004
How'd you finish in the A? That was my first win, still stoked over it.
#2006
Rex
#2007
I like the nova #5 in the argus but it really narrows he tuning window. If you are not spot on with your tuning I would go for a hotter plug. I got some of my best runtimes using the #5 but if you aren't 100% sure on your tuning it will cause head aches.
#2008
I guess I will just order some more OS plugs to be safe since they are working and I don't want an airleak.
I think I finished 8th in the A main. That track is very tuff and technical. Love it though. I love tough tracks since they make you a much better driver.
#2009
Rex
1Likes
