1/12 forum
There are a couple others out there. I know HobbyKing makes one: http://www.hobbyking.com/hobbyking/s...up_System.html
But, honestly, I've always used Hudy. Their stuff is just so well made I think the price is justified.
I have the Kyosho... It works great & allows you to set the cam the the size tire you run.
http://www.tqrcracing.com/shop/produ....asp?p_id=5010
Crush tubes for the front wheels/bearings? Worth the trouble? Available anywhere?
The Kyosho setup station is really nice.
To make it work, you have to shim each crush tube individually for each wheel you use which is time consuming. I've never seen them anywhere because it is too hard to make them work as they should.
HTH
Not needed at all. Unless you tighten the wheel nuts to the point that the wheel won't spin. Then you would also need wheel nuts that only contact the inner race.
I recently bought this setup station and it's great! If you're considering purchasing it then I would suggest you watch this video.
https://www.youtube.com/watch?v=yqAMdYSRSpo
Edward, can you tell me what caster blocks you have on that car & possibly where to order?
Thanks...
You'll have to Goolge to find out where you can buy it.
You can try... Futaba Pro Shop Futaba Sangyo
Thank you!
2991Likes
