Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 06-17-2015 | 03:17 PM
  #4096
robk's Avatar
Originally Posted by Sydewynder
If the rules set by RobK state Roar motors, how does modifying the motor to get more timing work?
Well you can see how this stuff always goes. Then again, I have watched people grind other brand motor's timing rings because the initial production had less timing than subsequent production runs. I didn't think it was a big deal or cheating, but of course no one can use any common sense to think critically about this stuff. I just hear "I'm gonna take 5 winds off the stator and put in a mod rotor HEEEEEEEHAAAAWWWWWWWWWWWWWWWWWW"
Because that is the exact same thing as getting the extra 5 or 10* of timing that every other motor has.
This is not really directed at you sydewynder, it's just what everybody does when you open the door even a crack. It's why we can't have nice things around here.
robk is offline
Old 06-17-2015 | 03:21 PM
  #4097
howardcano's Avatar
It seems there are those who interpreted my post as I will modify the motor any way I want. Far from it. My point is if you allow one thing others will see it as not following the set rule and they can do other motor mods. Thus my saying "you are opening a can of worms". Those that buy a specific motor should run it as is. If you don't like any part of a motor then don't buy it..
Fair enough.
Keep in mind that the rule set is determined by only one person, RobK, and if anyone has a question as to what is or isn't allowed, he will usually respond within a short time right here on RCTech. (EDIT: Which he just did!)
I don't always like all of the rules either. But I do like being able to get an official answer nearly instantaneously, without waiting for a committee to vote on something. Benevolent dictatorships or monarchies can be very efficient!
howardcano is offline
Old 06-17-2015 | 04:03 PM
  #4098
scirocco14's Avatar
Rules are always divided into "letter of the rules" and "intent of the rules". Races can only go by the letter, because we rarely have any insight into intent when the rules are written.
Just add "timing rings may be modified to increase timing adjustment available".
Done.
Or don't allow ANY modifications to a stock ROAR approved motor. Then each motor will have to stand on its own merit, warts and all.
Thanks for putting up with us, RobK.
Mark
scirocco14 is offline
Old 06-17-2015 | 06:01 PM
  #4099
IndyRC_Racer's Avatar
My experience has been that when I spend more time making my car's setup better, my lap times improve more than when I worry about a better battery or motor.
While I like to challenge for the podium every time I race, over the years I've learned that I'm really racing against the clock and myself. Even if I'm running an "inferior" motor, "old" battery, or "obsolete" chassis, I can still try to get the most out of the equipment I've got. On those rare days that I do get everything right, it is one of the most rewarding feelings I can get racing.
IndyRC_Racer is offline
Old 06-17-2015 | 06:10 PM
  #4100
trytowin's Avatar
With all the rain we've been having lately, I'll be running a 4 blade 22 degree prop, anybody have a problem with that ?
trytowin is offline
Old 06-17-2015 | 07:08 PM
  #4101
Is that a detongued prop? You know that's a mod..
Sydewynder is offline
Old 06-17-2015 | 08:06 PM
  #4102
Box Stock or Sharpened and Balanced???
mooby64 is offline
Old 06-17-2015 | 08:45 PM
  #4103
DARKSIDE's Avatar
Im telling....
DARKSIDE is offline
Old 06-17-2015 | 10:59 PM
  #4104
metalnut's Avatar
This is very well said and I think describes the spirit of RC racing better than anything else. It's a thought angle that I often forget myself. It's easy to throw money at the latest and greatest (says the guy who runs a T4 2015 with top of the line electronics in a 25.5 VTA-ish class), but in the end you have to remember to have fun. It's not only about winning and many things go into making a good race day/night.
metalnut is offline
Old 06-18-2015 | 03:44 AM
  #4105
I feel the pain whenever I see people modifying motors internally in spec classes.
old_dude is offline
Old 06-18-2015 | 06:33 PM
  #4106
Show me in the ROAR Rules where it states you cannot alter the timing range of a motor, because I cannot find it.
Grinding the timing ring does not alter any base dimensions or specifications of an approved motor. I've never had to max the available timing on any other motor, so trying to get more out of those would only melt it into a puddle.
edit: If ROAR cared about timing range they would set a max internal+adjustable percent I would think.
Just to make things clear, I run TSR's because they are awesome but I feel the Trackstar is good for the longevity and affordability of the sport.
nwagner is offline
Old 06-18-2015 | 06:42 PM
  #4107
Ron, it pains me to see people dropping $170 on a motor for spec classes.
nwagner is offline
Old 06-18-2015 | 06:53 PM
  #4108
scirocco14's Avatar
Show me in the ROAR rules where it says you are ALLOWED to alter the timing range. I cannot find that either.
Mark
Old 06-18-2015 | 07:09 PM
  #4109
Does ROAR measure the available timing of a motor as part of it's approval process?
If they don't....
nwagner is offline
Old 06-18-2015 | 09:26 PM
  #4110
Rabbit0317's Avatar
The guys that do this are the ones who destroy spec class racing. It usually the ones who aren't the best drivers, knowing they couldn't be competitive in a mod class and can't stand loosing. They killed the stock Slash off-road class by me and I hope they stay away from our on-road. This class is the most competitive and fun class I have raced alongside 17.5 buggy.
Rabbit0317 is offline
