Like Tree12Likes
Tekno NB48
Old 05-04-2015 | 08:56 AM
  #3331
Originally Posted by Carter Flotron
Pete is right. While technically they will 'fit' the current buggies (NB48 and EB48.2) youd need the new rear hubs and extenders and some other small parts from the SL kit to really get it to work correctly.
From what it looks like this will be the case. I think the aluminum rear hubs Bornhorst and Lutz have been running were made to fit either, but don't qoute me on that.
Even if you made the hubs and extenders fit, the SL arms still would not yield the same geometry. The SL arms are the narrow width parts like the SC truck.
MX304 is offline
Old 05-04-2015 | 10:35 AM
  #3332
Carter Flotron's Avatar
I know I didn't say it would work well. They have the ability to be installed on the car, but they wont handle well at all or be worth it in any sense.
Carter Flotron is offline
Old 05-12-2015 | 10:50 AM
  #3333
slakr's Avatar
So where are all the NB48's (out of stock)? Is there a new buggy coming out or something?
slakr is offline
Old 05-12-2015 | 11:00 AM
  #3334
WonTonsChicken's Avatar
Very possible..
WonTonsChicken is offline
Old 05-12-2015 | 12:12 PM
  #3335
Updated buggy coming out. Looks to be 2-3 months out.
MX304 is offline
Old 05-13-2015 | 06:33 AM
  #3336
Hoese37's Avatar
https://www.google.com/shopping/prod...AYWjsAWL9IGIBw some available here.
Hoese37 is offline
Old 05-16-2015 | 06:53 AM
  #3337
I ordered a set of truggy shocks, towers and some springs if anyone who has already modded there arms would be willing to post some pics Iit would be very appreciated.
jt409 is offline
Old 05-19-2015 | 07:26 AM
  #3338
So when are the New parts coming out???
Any Word tekno?
segreda is offline
Old 05-21-2015 | 11:52 AM
  #3339
Originally Posted by blacktop20valve
its all direct fit, the guide just makes the rotor more straight, i used a spring instead of a fuel tubing as seen on the pics, its more consistent, coz the tubing gets softer when its hot, the spring came from a D8
I know I'm responding to an old post and on the buggy thread, but I have a NT48 and one of the brake pads came off the metal piece. I'm assuming the Kyosho brake setup will fit the NT48. Anyway, did you just buy the brake pads and disk or did you have to buy the pad mounting posts too? What brake disc guide is that? I'm interested it that too. Thanks.
qstorm777 is offline
Old 05-21-2015 | 06:32 PM
  #3340
nmdesertracer's Avatar
One of the best upgrades for the brakes!
TKR5206 brake discs
TKR5214 brake pads
TKR5215B 10° Offset Steel Brake Cam
nmdesertracer is offline
Old 05-21-2015 | 07:20 PM
  #3341
FastPete's Avatar
TKR5206 brake discs
TKR5214 brake pads
+1 did it to mine also works great!
FastPete is offline
Old 05-21-2015 | 09:20 PM
  #3342
TKR5206 brake discs
TKR5214 brake pads
Really? Cheaper too. How long does the fiberglass discs last? How do they compare to stock?
Old 05-21-2015 | 09:55 PM
  #3343
8ight-e's Avatar
is there any way to make the nb48 turn like my eb48.2?
8ight-e is offline
Old 05-21-2015 | 10:03 PM
  #3344
Can you post your setup? I run pretty much the same setup for both cars.
Old 05-21-2015 | 10:08 PM
  #3345
8ight-e's Avatar
I don't have it in pdf, it was based on one of Joe's. Do you have a copy of your setup? I was thinking of using one of Ryans as a base, but his are pretty old.
8ight-e is offline
