Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-12-2015 | 07:24 PM
  #3931
MikeR's Avatar
Thumbs up
My new Pagani. Worked awesome....
MikeR is offline
Old 05-12-2015 | 08:00 PM
  #3932
wwddww34's Avatar
Cool Zonda F, Mike! Is that a PRO4X V2 under that shell?
wwddww34 is offline
Old 05-13-2015 | 09:02 AM
  #3933
MikeR's Avatar
Yes HPI Challenge pro electric class- TQ, win and concourse win!
Seemed to give my car the edge on the straightaway. Note I cut the wing down further than this to reduce drag and a high speed push
MikeR is offline
Old 05-13-2015 | 11:39 AM
  #3934
NutDriver's Avatar
200mm body?
NutDriver is offline
Old 05-13-2015 | 11:47 AM
  #3935
howardcano's Avatar
Originally Posted by NutDriver
200mm body?
My Zonda measures 200mm front, 202mm rear.
howardcano is offline
Old 05-13-2015 | 12:34 PM
  #3936
JayL's Avatar
Originally Posted by rcgod
Anyone have suggestions with R1 21.5 premium motor-gearing and timing? I tried from 3.8 to 3.2 final gearing and played with timing but motor never got above 120 deg. I did feel some fade after a couple of laps at 3.2 but motor didn't get hot. Ended up at 3.8 and 40 deg timing for the main. Motor came off at 110. I have a 30mm fan on the motor too. Thanks.
Just run what Scotty runs, he has fast lap and his motor doesn't fade
Last he told me it was 3.67FDR 20Timing
you can't gear just on temp, especially when our track will be 160F+ soon
gear so it is fully wound out before the last light post ish
Also speed and FADE are also about battery big time....
JayL is offline
Old 05-14-2015 | 08:12 AM
  #3937
My Ferrari 458 is almost done. I really like the lines of the car (especially since the series I run here in TX doesn't allow the Daytona Prototype bodies) but the interlocking jigsaw puzzle-like decals that Tamiya provides suck particularly because you have to cut them out by hand. The color of a Ferrari IMO should project attitude and the picture doesn't really capture the true attitude of that yellow. At least it should be very easy to see on a bright sunny day.
John Wallace2 is offline
Old 05-14-2015 | 08:31 AM
  #3938
Sick....what wing is that please?
racenut123 is offline
Old 05-14-2015 | 08:34 AM
  #3939
wwddww34's Avatar
Hi John, what is the series that you run in Texas? What city in Texas do you live?
wwddww34 is offline
Old 05-14-2015 | 08:39 AM
  #3940
rcgod's Avatar
Awesome thanks for the info. I have a feeling the fade I felt was battery related since it was the first run on the new pack. I'll go up a tooth on the pinion which will put me at 3.7 and lower timing.
rcgod is offline
Old 05-14-2015 | 08:48 AM
  #3941
MikeR's Avatar
I think it's an old protoform P37 wing that is cut down and mounted to HPI wing mounts with the angle shims used.
MikeR is offline
Old 05-14-2015 | 09:11 AM
  #3942
EOS (Electric On-road Series). I live in Floresville, just South of San Antonio. PS I just updated my profile to include where I live - it wasn't there when you sent your post
Old 05-14-2015 | 01:10 PM
  #3943
Looks good John. You always have some of the sweetest looking rides.
Joe Maxey is offline
Old 05-14-2015 | 02:29 PM
  #3944
SpidarX's Avatar
I like it. Now there will be two Ferraris, although I'm not quite ready to put scratches on mine yet.
SpidarX is offline
Old 05-14-2015 | 06:48 PM
  #3945
Thanks, now if I can just keep up with you.
