Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 11-03-2022 | 10:34 PM
  #11431
Originally Posted by Sabin
I picked up the new belted tires. So far, they have two days on them. Looks like they'll take some time to break in.
I've tried them at the local track. I had to add 2 degrees of camber (1 static and gain of one on compression) to the rear to keep the rear planted. Anyone else feel like they take away rear traction mid-corner?
VirtualBum is offline
Old 11-04-2022 | 11:06 AM
  #11432
MikeR's Avatar
On asphalt, they take away grip on all corners haha
STLNLST and glennhl like this.
MikeR is offline
Old 11-09-2022 | 12:17 PM
  #11433
I do something similar on my FG sportline, a Flying Lizard Porsche GT2 LeMans replica.
Kregger, egalsim and NutDriver like this.
Alain Patry is offline
Old 11-15-2022 | 02:39 PM
  #11434
What is required for the new(er) usgt wheels to work on A800? The offset is a couple mm higher
AsphaltFlyer is offline
Old 11-15-2022 | 05:33 PM
  #11435
Mine work fine on the rear, but on the front I went to the thicker AT13W wheel hex.
AsphaltFlyer likes this.
glennhl is offline
Old 11-18-2022 | 04:40 PM
  #11436
I am sure this has been asked in the past but I am new here and reading 700+ pages of posts is really hard.
I am looking for USGT body advise. I just raced a Seven20 last weekend and it was fine but wondering if Exotek R-Tek and P1-Z are better bodies.
Any help would be greatly appreciated.
StueyLewis83 is offline
Old 11-18-2022 | 05:26 PM
  #11437
for my track, the p1-Z is the go to..
glennhl likes this.
timberline97 is offline
Old 11-18-2022 | 05:40 PM
  #11438
Exotek P1-Z or Zoo Bwoah are really the only bodies to consider.
JeffC is offline
Old 11-18-2022 | 05:53 PM
  #11439
MikeR's Avatar
Carpet or asphalt? Big track or small track? It's all relevant.
MikeR is offline
Old 11-18-2022 | 06:40 PM
  #11440
Black carpet track around 90' x 50'.
Old 11-19-2022 | 12:27 AM
  #11441
R/C Tech Elite Member
My opinion from running both:
Exotek P1-Z - High Bite Black carpet
Zoo Bwooah - Low/Med Black carpet
Robbob is offline
Old 11-19-2022 | 08:53 AM
  #11442
DARKSIDE's Avatar
come on Jeff, really.... anybody can make any body fast and win if you tune it to the chassis...some bodies are just easier to get there like the P-zero...but Ive won with different bodies including the PF C8 and Ford GT....
I say pick a body you like and tune it from there... be different and show out
DARKSIDE is offline
Old 11-19-2022 | 08:54 AM
  #11443
DARKSIDE's Avatar
all Im saying is run what you like...
Raman, angrymelon and simple like this.
DARKSIDE is offline
Old 11-19-2022 | 09:22 AM
  #11444
Default Bodies
You almost always run on carpet where body has less effect . High grip and dialing grip out is easy. Fighting to gain grip on low bite asphalt with unbalanced bodies that have little downforce or are one or the other . Is harder to make a car handle . It’s easier to stick with bodies that work or are more balanced
DARKSIDE, jo_er86 and V8 Rumble like this.
john holmes 69 is offline
Old 11-19-2022 | 02:15 PM
  #11445
DARKSIDE's Avatar
yep
simple likes this.
DARKSIDE is offline
