Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 09-28-2022 | 01:15 PM
  #11401
DARKSIDE's Avatar
DARKSIDE is offline
Old 09-28-2022 | 01:34 PM
  #11402
Has anyone mounted a ZR Bwoah on an XRAY T4'21? Just eyeballing it, I'm not sure the rear body mounts will go low enough? Just curious what others have done before making some holes.
bentouttashape is offline
Old 09-28-2022 | 06:07 PM
  #11403
Ivan Dickson's Avatar
Yes, just need to use ultra low shock towers.
Ivan Dickson is offline
Old 09-29-2022 | 10:00 AM
  #11404
Front and rear or just in the rear?
Old 09-29-2022 | 02:15 PM
  #11405
HenryC's Avatar
I thought the T4'21 came with ultra low shock towers. I had no problem mounting the BWOAH! on my T4'21 as well as X4.
HenryC is offline
Old 09-29-2022 | 02:37 PM
  #11406
Perhaps Ivan is referring to the "Lower" ULP?
It appears that there are two ULP tower options:I believe it moves both the shock and body post holes down by 4mm?
Henry, do you have any pictures of your BWOAH mounted up to your T4'21? Both with and without the body?
Ivan Dickson likes this.
Old 09-30-2022 | 04:30 AM
  #11407
simple's Avatar
Post further up the forum.. took 3 clicks...
USGT
bentouttashape likes this.
simple is offline
Old 09-30-2022 | 08:34 AM
  #11408
HenryC's Avatar
Not sure what this photo would tell you. It is mounted on a box stock T4'21 in this picture. I used horizontal body posts for mounting the rear. Otherwise the rear vertical body posts will be right next to the rear wing.
Taz_S, Ivan Dickson, JCarr and 2 others like this.
HenryC is offline
Old 09-30-2022 | 10:11 AM
  #11409
I know what your photo tells me. You are a FANTASTIC painter!!! Great job.
mr.rev likes this.
glennhl is offline
Old 10-05-2022 | 07:38 PM
  #11410
Yes you are correct ,,,Lower ULP
Old 10-05-2022 | 07:39 PM
  #11411
go with both F & R
Old 10-06-2022 | 09:26 AM
  #11412
Thanks for the advice, Ivan/Henry.
Old 10-15-2022 | 02:01 PM
  #11413
rob martin's Avatar
Originally Posted by Raman
Slightly exaggerated rear fender, used to have mould line on back 😉
Are the ride usgt tires/wheels legal
Looks good btw
rob martin is offline
Old 10-15-2022 | 05:18 PM
  #11414
Raman's Avatar
Looks good btw
Seems they have been made legal for indoor / carpet
Raman is offline
Old 10-19-2022 | 07:05 AM
  #11415
mrreet2001's Avatar
R/C Tech Elite Member
From the current rules.
Tire & Wheel Specifications:
Tires-
CARPET p/n GRC123 (GRAY wheels) set of 4 available through Gravity RC http://www.teamgravityrc.com/ to dealers and retail
ASPHALT/OUTDOOR SURFACES
Mounted - GRC123, GRC124, GRC124GTB, GRC124GTW Unmounted tire - GRC125
Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed MUST USE INCLUDED INSERTS
Wheels- Any 24mm - 26mm spoke (non-dish) type wheel
mrreet2001 is offline
