Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 04-06-2015 | 10:44 AM
  #3796
howardcano's Avatar
Originally Posted by wwddww34
Has anybody tried racing with the HPI #17523 Pagani Zonda F body? Did it work Ok? What are its Pros/Cons?
Yes, it looks great! I needed to mount a larger wing to get the handling balanced. And make sure you leave the front splitter on!
It's a wide body, so you may prefer to run a wider track on your chassis. I didn't, because the extra width on the front keeps the inside tire tread covered enough at full steering lock to prevent riding up a flapper and rolling over when cutting an apex too tight.
howardcano is offline
Old 04-06-2015 | 10:46 AM
  #3797
robk's Avatar
The Zonda is good. I ran it on asphalt last year and it was pretty neutral. I did run a molded wing so rear downforce was good.
robk is offline
Old 04-06-2015 | 11:22 AM
  #3798
NutDriver's Avatar
"Riding up a flapper".....bet someone from the Roaring 20's would get a grin from that. ��
NutDriver is offline
Old 04-06-2015 | 11:24 AM
  #3799
NutDriver's Avatar
http:// http://www.trutv.com/graphic...harleston2.jpg
  #3800
NutDriver's Avatar
Old 04-06-2015 | 01:51 PM
  #3801
howardcano's Avatar
I got the order right, too: First ride the flapper, then roll over.
Old 04-06-2015 | 02:44 PM
  #3802
IndyHobbies.com's Avatar
Default El Camino SS
I don't know what class this goes in, I just know I want one, bad!
IndyHobbies.com is offline
Old 04-06-2015 | 04:36 PM
  #3803
Will that fit into the rules of "No Trucks or Zambonis"?
mooby64 is offline
Old 04-06-2015 | 06:08 PM
  #3804
wwddww34's Avatar
It's not a truck. It's not a Zamboni. It's a ...
+ YouTube Video
wwddww34 is offline
Old 04-09-2015 | 03:39 AM
  #3805
theproffesor's Avatar
How well do the white ride rims take dye? I have a set of split 5 spoke that have a bit of purple tint to them. I want them black. But a real black. Not the really dark purple that a lot of dye jobs end up being.
Thanks for the help.
theproffesor is offline
Old 04-09-2015 | 04:27 AM
  #3806
I've tried a couple of times to dye the rims black and they wouldn't take the dye at all. I ended up using Exotek black rims which were 3grms heavier a piece. There are some new ride spoked rims that are black which come mounted or just the rims.
chuck
mackin is offline
Old 04-09-2015 | 06:03 AM
  #3807
Thanks for the info. I have had the exotic rims is the past and they cracked in several places along the inside lip of the rim. Plus I think the ride rims I have now would look great black. Could you post up a link to the black pre-mount. Only seem to be find I the white.
Old 04-09-2015 | 06:10 AM
  #3808
MD's Avatar
MD
http://www.teamgravityrc.com/store1/...=0&sort=normal
MD is offline
Old 04-09-2015 | 12:58 PM
  #3809
ThrottleKing's Avatar
I saw a set of USGT Pre-mounts on there GRC123 that were on dish wheels. I was under the impression that in the rules USGT requires a spoke or non dish type of wheel.
Has the rules changed?
ThrottleKing is offline
Old 04-09-2015 | 01:45 PM
  #3810
Thanks for the link. I guess the short cut I had was somehow to an archived page. Didnt show the new stuff. They do premounts on the dish wheels because some clubs run the ride tires in TC.
