TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 01-09-2015 | 07:44 PM
  #2776
Originally Posted by TLR_TeknoRC
Way to go! you will love the E3.0, I hope you still got the manual/book too, just go with the stock setup and your good to go.
Didn't get the manual, but should be able to find it online and print. I'll be running it at an indoor clay high bite surface SDRC Raceway. Will the stock setup be good for those conditions.
towertsk is offline
Old 01-10-2015 | 01:45 PM
  #2777
trixter91's Avatar
What pinion do I want with a 1900kv motor. I have a 20 tooth. Is that to much.
trixter91 is offline
Old 01-10-2015 | 03:53 PM
  #2778
trixter91's Avatar
Also are u guys using a 270mm sensor wire .
Old 01-10-2015 | 06:57 PM
  #2779
pimpedaccord's Avatar
Originally Posted by NickTheGreek
This is the pinion lined up the other way.....
Your gonna have to dremel the flat closer to the motor.
pimpedaccord is offline
Old 01-10-2015 | 06:58 PM
  #2780
15 or 16t pinion. Yes on the 270mm if you are running the batt back.
Old 01-11-2015 | 04:28 AM
  #2781
trixter91's Avatar
Cool, thanks. Are there any mods im gonna want as im new to ebuggy.
Old 01-11-2015 | 06:25 AM
  #2782
Aluminum servo saver top
dhickman is offline
Old 01-11-2015 | 07:17 AM
  #2783
trixter91's Avatar
Do u have a model number.
Old 01-11-2015 | 07:55 AM
  #2784
Dan.J's Avatar
TLR244021
http://www.amain.com/team-losi-racin...Product-Feeds&
Dan.J is offline
Old 01-11-2015 | 10:21 AM
  #2785
MasiisaM's Avatar
Im going to try RM surf city set up and it looks like i have everything to do it except the "8ight T 3.0 caster blocks spaced forward."...Does anyone know what part that is?
MasiisaM is offline
Old 01-11-2015 | 01:52 PM
  #2786
trixter91's Avatar
Originally Posted by Dan.J
Old 01-11-2015 | 06:13 PM
  #2787
Brian Miskolczi's Avatar
Truck front spindle carriers TLR244016
Brian Miskolczi is online now
Old 01-11-2015 | 07:43 PM
  #2788
A brother is ready to get his bash on.....
I might even decide to slick the hair back, throw on the wife beater n start slappin' it down with hop ups....Get my slap on.
NickTheGreek is offline
Old 01-12-2015 | 03:18 AM
  #2789
maddog9's Avatar
You will need to shim the caster. I used a scte steering rack bearing. I put the longer screw through the back and the short screw up front.
maddog9 is offline
Old 01-12-2015 | 07:04 AM
  #2790
rcmike's Avatar
Any must do or improvements for a 3.0 -E truggy ? Thx
rcmike is offline
