Like Tree12Likes
Tekno NB48
Old 12-03-2014 | 03:17 PM
  #2911
speedy2's Avatar
the mid kick-up inserts were blanc here too
I asked Ryan..
speedy2 is offline
Old 12-03-2014 | 03:19 PM
  #2912
madweazl's Avatar
Where did you find those selections? Most of the setups I see run B on the front camber links.
madweazl is offline
Old 12-04-2014 | 03:07 PM
  #2913
madweazl's Avatar
I removed the front shocks to check some things and noticed that the droop was being limited to 106mm by the shocks vice the droop screws.
madweazl is offline
Old 12-04-2014 | 04:52 PM
  #2914
JsK's Avatar
JsK
You can unscrew the shock rod ends a couple of turns and pick up a few more millimeters of droop. I have run my car like that and didn't have any trouble with the shock bladders. More droop and ride height tends to make the car feel a little numb and more forgiving.
JsK is offline
Old 12-04-2014 | 08:26 PM
  #2915
madweazl's Avatar
Absolutely, I was just noting the difference
As for Lutz' setup, he ran 0° sweep and 11.5° kick up and the front camber link was in position B (per conversation with him via Facebook).
madweazl is offline
Old 12-05-2014 | 08:49 AM
  #2916
Graham11's Avatar
Edit
Graham11 is offline
Old 12-05-2014 | 09:11 AM
  #2917
madweazl's Avatar
Dammit Graham, cut it out Part numbers?
madweazl is offline
Old 12-05-2014 | 10:36 AM
  #2918
Graham11's Avatar
Edit
Graham11 is offline
Old 12-05-2014 | 09:49 PM
  #2919
fastchvy's Avatar
Thumbs up
Big props to Tekno, i just built the car and im pretty picking on a few things and it went together butter smooth....Now lets see if it can handle as well as its built
fastchvy is offline
Old 12-05-2014 | 09:51 PM
  #2920
fastchvy's Avatar
what other bodies will fit this car?
fastchvy is offline
Old 12-06-2014 | 04:00 AM
  #2921
DBL15's Avatar
FTW has a body for the NB48 mate
DBL15 is offline
Old 12-06-2014 | 06:46 AM
  #2922
Harrison477's Avatar
This is the FTW Reactor body on my NB48.http://www.rctech.net/forum/attachme...1&d=1417877087
Harrison477 is offline
Old 12-06-2014 | 04:09 PM
  #2923
JsK's Avatar
JsK
Search this thread for FTW, Nightfox and Bittydesign. None from the Jconcepts
or Proline yet.
JsK is offline
Old 12-06-2014 | 10:24 PM
  #2924
Hoese37's Avatar
Originally Posted by Graham11
Edit
Edit
What did I miss?
Hoese37 is offline
Old 12-07-2014 | 06:26 AM
  #2925
Torian4000's Avatar
Originally Posted by Hoese37
What did I miss?
Released new product info prematurely.
Torian4000 is offline
