Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-03-2014 | 07:09 AM
  #13861
Hey everyone,I'm using the csi blue Pistons on my truck and buggy right now,they seem to work pretty well. Is their anything to be gained by using the fiorini two stage Pistons on a rough outdoor clay track?
Rickybob is offline
Old 12-03-2014 | 08:27 AM
  #13862
LowBoost's Avatar
Did anyone post a shock/diff oil comparison chart?
Maybe I saw it in another thread. Planing on using Losi oils
LowBoost is offline
Old 12-03-2014 | 08:29 AM
  #13863
vwduud's Avatar
This will get you close when going from CPS to WT and WT to CPS:
http://www.offroad-cult.org/Special/...wt_convert.php
vwduud is offline
Old 12-03-2014 | 08:45 AM
  #13864
Cain's Avatar
PT Racing oils has a nice chart comparing losi oils to there oils rating.
There are also a few guides out there for AE oils to losi oils, and AE also puts both ratings on there bottles.
speaking of which, if anyone is looking for a lot of Losi oils, shoot me a pm, converted here and will be selling a variety.
Cain is offline
Old 12-03-2014 | 08:47 AM
  #13865
vwduud's Avatar
Not sure of the source of this. As far as the AE to Losi, this does seem to conform to what I hear others claim.
Jim
File Type: pdf
vwduud is offline
Old 12-03-2014 | 09:51 AM
  #13866
Yeah, if the PT data on other brands is correct, it's a bit disturbing. I have a bunch of the PT on the way to try.
RokleM is offline
Old 12-03-2014 | 09:53 AM
  #13867
cpt_RedBeard's Avatar
Here is the one I use when talking Losi to CST. And as mentioned above, AE puts the CST rating on their bottle.
cpt_RedBeard is offline
Old 12-03-2014 | 11:01 AM
  #13868
LowBoost's Avatar
Anyone knows if the SCT410 turnbuckles are the same for the EB48.2?
Anyone tried Lunsford titanium kit?
LowBoost is offline
Old 12-03-2014 | 11:04 AM
  #13869
the lunsfords for the sct will work on the eb48.2
micrors4guy is offline
Old 12-03-2014 | 12:08 PM
  #13870
what weight oil you running?
turtle189mt is offline
Old 12-03-2014 | 12:29 PM
  #13871
35 front 30 rear for buggy 32.5 front 27.5 rear for the truck
Rickybob is offline
Old 12-03-2014 | 04:13 PM
  #13872
OK...NEED HELP!
Finishing up this build and have an issue with the clearance of the nut on the end of the screw that goes through the steering arm and through the hub. It gets stuck on the A arm. When the car is sitting normal without compressing the shocks it looks like the following... when I push the chassis flat it clears without a problem. I checked the and rechecked and I believe it is assembled correctly. Per the instruction, the initial bumpsteer setting two washers above and below the steering ball link. I took one washer out from above and below to see if that would help, but it didn't... I made sure I am using the correct ball with the flange faced correctly. I hope I explained it correctly and the picture helps. Thanks for any help you could lend!!
worm304 is offline
  #13873
Cain's Avatar
got the carrier on the right way?
Cain is offline
Old 12-03-2014 | 04:33 PM
  #13874
Stubbs's Avatar
Originally Posted by worm304
OK...NEED HELP!
The nut isn't seated in the hub properly. It should be much deeper.....
It's a loose fit, and might have popped out when you put the screw in, then partially pulled in when you tightened it. You should be able to just barely see the top of the nut when it's fully seated.
Stubbs is offline
Old 12-03-2014 | 04:36 PM
  #13875
OK...NEED HELP!
I don't remember the nut sticking out that far on the bottom. Is that a washer on it that I see? I thought the nut seats into the hub arm there...I will check mine when I get home.
justinco is offline
