Sirio engines thread
#782
Originally posted by Dynamite
its a kodak dc3200, borrowed it of my dad, i think it is only a 1megapixel? i will try tomorrow when my step dad gets back home from o/s he has a beauty of a camera.
#784
Does the Sirio S12TUP Turbo SG engines come in both 3 and 5 ports? Trinity website shows only 5 ports, but an overseas shop said he has one with 3. Any help would be appreciated
#785
The Trinity site is outdated and poorly maintained. There is a 3 port version. you can find it at www.speedtechrc.com
#786
New Sirio 3 ports are S12 TRP EVO2 I(IFMAR) or E (EFRA)
and the recently S12 WCR (World Cup Replica).
AFM
#787
Originally posted by afm
Sirio TUP 3 ports is old early Sirio. The new TUP's are only 5 port.
AFM
AFM
#788
Thanks for clarifying that one. Is it still a competitive engine? Any comments about it would help as I found one $130.00 NIB
AFM
#789
hi guys! i'm thinking of getting another engine for my 1/10, the Sirio S12-TUP in particular. But i heard that there are actually 2 versions, one is the standard 5 port while the other one is a 5 port factory modified (or something like that!) both have the same part numbers. Btw, they are priced at S$295 & S$380 respectively. can anyone confirm?
#790
AFM
#791
Can you give me part numbers?? And is there a site were I can check them to give you an answer as to what you're beeing offered??
AFM
AFM
#792
hi afm.. thanks for the fast reply! the label outside the box says ''Sirio S12-TUP Sirio Engine 2.1cc 5 Ports ABC Slide Carb. SG Shaft''.. that's for both the standard 5 port and the 5 port factory modified.. I saw it at Hobbybug (www.hobbybug.com) this evening.. the shop owner said it's not in their website yet..
3 ports Slide carb SG crank:
S12 WCR World Cup Replica
S12 TRP E EFRA specs
S12 TRP I IFMAR-ROAR specs
S12 TSP Econo Model
3 ports rotary carb SG crank:
S12 TRR E EFRA specs
S12 TRR I IFMAR specs
5 ports Slide carb SG crank:
S12 TUP 5 ports
Don't know of any factory modified Sirio 5 ports, maybe it's modified by somebody else. BEWARE.
The only Sirio based engines that I now as factory modified are the Lamberto Collari engines, modified by his father Mauro Collari.
that are sold by www.werksracing.com and as i speak they only had the regular Collaris 3 and 5 port, but were going to import the Mauro Collari modidfied versions.
AFM
#793
so whats the key to getting the best performance out of the new sirios, i have the 3p version. i race another guy with an older sirio and it screams, mine is not too shabby but i can tell that its can be faster. i think i run it too rich over all but it gets very hot sometimes i dont want to toast my motor, be ther done that, ot fun. he has a aftermarktet head on his and it is running way cooler than mine but thats not the whole fix im sure.
#794
Sirios like to work at their best around 250ºF, but also you must have your car properly geared. If you have it to long geared in a short track, engine will heat up and vicecersa.
Standard cooling head from the EVO2 is enough.
AFM
#795
i guess that is about the temp i see it just seems high to me, im winning at that temp it just seems that it would be one of the fastest cars out there at that temp, im running the stock gearing in the mtx3 when i hit the track again i geuss i just need to pay close attention to the settings
1Likes
