Tekno NB48
#2406
#2407
And one note about tank
(quote from NT48 thread)
It is a good idea to replace those screws on buggy tank too, esp. outer two from the pipe side. I've interchanged them with batt cover screws, because they're too short for radiotray to have a good grip. Inner two screws are ok because there is splash guard adding amount of non-threaded area.
On the tanks leaking, this is due to the screws that secure the fuel line clips being too long (M3x8mm). Replace them with M3x6mm screws and everything should be fine.
#2408
#2410
I was looking at some of the pics from the fuel tank topics and noticed that it seems just about everyone has routed their fuel lines differently than the instruction book. I spent about 20 minutes trying out different setup before settling on one but was curious as to what everyone had come up with.
Also, after the various dialog about the brakes/linkage, I ended up with what is in the image below. Was hoping to test it out this weekend but there is a $50,000 fishing derby up here that I just cant resist (that buys a lot of tires!) so it will have to wait a bit longer. Parts are from the JQ white edition (no clue if they're different from the yellow or original), mostly because I have a thing for orange (disregard the lone original collet there, I have another JQ bag on the way
). I trimmed the spring bit by bit until I got a tension that seemed good and also that the servo didnt object to. Sure hope it helps out.
#2411
#2412
#2413
). I trimmed the spring bit by bit until I got a tension that seemed good and also that the servo didnt object to. Sure hope it helps out. By the way, I love that power button but the Kyosho one has a full LED reading to show battery life and some other cool features, unfortuatenly its more expensive. Thunder Innovations has an aluminum orange version of the one you have, thought you might like that, check the link.
http://www.thunderinnovation.com/ProductView.asp?ID=247
12Likes
