Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-30-2014 | 05:35 PM
  #13366
The shock bodies and shaft guides are different.
masher81 is offline
Old 08-30-2014 | 06:48 PM
  #13367
Cain's Avatar
had a fun day today doing some group running a track part of guys house. Low turn out of guys who like to race, but a group of them who regularly travel to the larger races in MN .
The conditions were black dirt, that when watered I would say offers about medium level traction. As it dries out it goes to dust. Tires like a Blockade work quite well. Didn't have any for my 1/8 scale but settled on AKA I-Beams in soft compound and htye worked quite well.
Track was small enough that on my Tekin 1900Kv motor I was down to a 14T pinion and that felt really good.
with the setup I am using, I round that I needed a bit more bite so I decided to move the shocks in 1 position on the tower and that felt really good.
I am thinking though going to 6 hole 1.5mm pistons as well as on my SCT410 they just seem to soak stuff up better than a 1.3 x 8 hole setup. I think that last bit will help with the bit of jittery feeling at times I would get. In general was good, just once in a while didn't feel as confident as I wanted it to. And the PRCP Track is much more bumpy so wanting to get that smooth glide feel. If anyone has tips, let me know. Can post my full setup if that helps.
Damage for the day was the original ackerman plate that the EB48s came with, finally broke so I put on the upgraded version. I also managed to snap a CVD as the outdrive wore enough I believe to cause it to bind. Will throw in some spares I have.
All in all a good day, believe I may have put down the fastest lap time in both 1/8 E buggy and 1/10 SCT, though small group, good group, had a blast.
Cain is offline
Old 08-30-2014 | 08:03 PM
  #13368
FastPete's Avatar
Sounds like a fun day Cain. I will be getting mine going soon for our winter indoor season.
FastPete is offline
Old 08-30-2014 | 09:32 PM
  #13369
Cain's Avatar
yeah, definitely was fun!
Alright, question for everyone, just saw the most recent posted setup using 6 x 1.5mm pistons here:
http://www.teknorc.com/tekno5/wp-con...MediumBite.pdf
is this a good setup to try on low bite, if not, what should be first place to start changing?
Cain is offline
Old 08-31-2014 | 07:45 AM
  #13370
Finally, my buggy is ready for Bring The Heat next weekend in Flowood, MS. Rebuilt the entire car with all new plastics and drive train, new lrc mount and milled shock bushings. The car is as ready as it is going to be.
micrors4guy is offline
Old 08-31-2014 | 08:47 AM
  #13371
FastPete's Avatar
Looks nice Rob, you paint it?
FastPete is offline
Old 08-31-2014 | 08:50 AM
  #13372
Yep. Im too busy painting bodies for everyone else i have to keep mine simple. I think i have 22 bodies at the house right now inline for paint.
Old 08-31-2014 | 09:33 AM
  #13373
cpt_RedBeard's Avatar
Cain, I'm Jeff Beck. I ran that setup again this weekend with a lower bite track and it still worked great. That setup was developed with help from Mr. Tekno himself. The key to the shock setup is using the outer upper holes in the arms to increase the shaft speed.
That setup is extremely aggressive. It has gratuitous amounts of steering. If you find it hard to drive start with lowering your dual rate and or moving the Ackerman position back to center to help tone it down.
cpt_RedBeard is offline
Old 08-31-2014 | 09:43 AM
  #13374
Cain's Avatar
cool thanks.
I am going to do some comparisons here and see what I can appropriate to what I have.
probably the biggest thing for me would be the rear camber link location as that appears different than what I am seeing on other setups, what did you notice with this location?
Cain is offline
Old 08-31-2014 | 09:46 AM
  #13375
tony montana's Avatar
Originally Posted by dpilk08
anybody have any recommendations where i can get my new finnisher body custom painted?
You get your car yet?
tony montana is offline
Old 08-31-2014 | 09:47 AM
  #13376
cool thanks.
That location gave the car more rear traction overall. It allowed the chassis to roll and recover better than the inner middle hole I normally use.
Old 08-31-2014 | 09:54 AM
  #13377
Cain's Avatar
good stuff, looking forward to giving it a try. Will see what I change here and report back.
Cain is offline
Old 08-31-2014 | 10:18 AM
  #13378
suzukipro's Avatar
Anyone with the old shock cartridges use one older style (black) shock guide in with their new delrin shock guides or does everyone drill them? I am a bit reluctant to drill mine so I substituted a older style black guide in the middle of the delrin guides between the O'rings, maybe new cartridges will be on my shopping list in the near future...
suzukipro is offline
Old 08-31-2014 | 11:18 AM
  #13379
FastPete's Avatar
I like it. Sounds like I need to send mine to you. I can barley paint one color.
FastPete is offline
Old 08-31-2014 | 11:58 AM
  #13380
For those that polish the shock shaft. Non tiNi. What are you using?
one8updragracer is offline
