Arrow Racing GTR .21 Engine Thread
#1307
Set the mid to 2 turns out from flush at 2 oclock and leave it there. Then it will adjust like a 2 needle carb.
#1309
Having serious problem to fine tune, when WOT, feel like starving for fuel but still extreme rich hsn. Change 2 new plug but same problem. 10th tanks...
Hsn-3 turn out from full close
Msn-2 turn out from flush 2pm
Lsn-1.25 turn in from flush
Plz assist
Plz assist
#1310
Have you fiddled with your idle gap? Make sure the idle gap is small - like 1mm or less.. As you close the idle gap, you generally need to lean the LSN to raise the idle back up - and vice versa.. I'm not a tuning expert, but often I find richening the LSN helps get things in the ballpark if a tune is playing hard to find... (but that is sometimes also compensating for a too-big idle gap..) The trick is finding the balance between the idle gap and the LSN - the HSN is simple..
All I've ever heard about MSN's is ... don't mess with them.
#1311
#1312
I did some reading, i think my tune got problem in the transition from mid to top end if the plug happen to be good. Should i lean the mid needle .5turn n richen lsn .5turn. I think just leave the hsn rich for safety. Any opinions? Thanks in advance
#1313
I would lean the top to 1.5 turns out and see what is does on a full throttle run. If it cuts out, then richen it and re-test. The bottom end is mainly for idle speed. If it won't clear out from a 10 second idle, then lean the bottom also.
The pipe, plug, and fuel will change what the top and bottom needles need to be set at.
#1319
From what i learnt in this forum. Is a good carb. Get the msn set then dont tune it. It it tune like 2 needle
#1320
Yes the carb is good now, you just have to have the mid range 2 turns out from flush at 2 o'clock. Then it tunes just like an OS carb.
The seals and the carb insulator have all been improved since the original version also.
