Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 06-16-2014 | 01:57 PM
  #2986
Mizchief's Avatar
Originally Posted by trevcoll
I was very happy with he FTW body for my 8ight-E. It was quite durable. Hopefully if they decide to crank one out for the ET48 it will be of the same quality. I'd buy one just to find out!
Yea I did a FTW buggy body the same time I painted a new tekno truggy body. The FTW body felt at least twice as thick.
Mizchief is offline
Old 06-16-2014 | 02:20 PM
  #2987
Registered User
yay I pull the trigger and my et48 on its way
TheMuffinman is offline
Old 06-16-2014 | 03:32 PM
  #2988
cannonballs's Avatar
hey guys,
Got a question for ya. During acceleration I am getting a high pitch whine sound, the sound goes away after about 3/4+.. What an this be a sign of? My motor is running at about 135 and I'm getting throttle pauses sometimes ( I'll post about this isn the Viper VTX8 forum). Mostly wondering about the whine, just doesn't seem normal to me. My setup includes: VTX8 esc, tekin 2000kv motor, truck is completely stock specs.
cannonballs is offline
Old 06-16-2014 | 03:33 PM
  #2989
double post
Old 06-16-2014 | 04:07 PM
  #2990
Anyone know of a stainless screw kit available for the ET48?
iScream is offline
Old 06-16-2014 | 04:52 PM
  #2991
mydudrevo's Avatar
Originally Posted by cannonballs
hey guys,
Mine is doing the same thing. High pitched whine like a bad bearing so I thought it was my motor bearings so swapped in another motor I have. Same thing again so I cleaned all the bearings in the truck and it still whines form 1/2-3/4 throttle. It's running fine though so I gave up trying to fix the sound and just drive it lol
mydudrevo is offline
Old 06-16-2014 | 05:55 PM
  #2992
GaMudDawg's Avatar
I love the FTW truggy body for the Losi and if they made one similar for the Tekno I would buy two of them to racing and practicing.
GaMudDawg is offline
Old 06-16-2014 | 06:51 PM
  #2993
Mizchief's Avatar
I never had good luck with those stainless steel kits. Always stripped and got bent easy. I just picked up a bunch of individual bags of teckno screws to share between the whole fleet.
Mizchief is offline
Old 06-16-2014 | 07:15 PM
  #2994
Dont know about "kits" to say, but I have gotten screws from these guys for years. They will not strip. Although I do prefer the steel alloy over the stainless.
Old 06-16-2014 | 07:19 PM
  #2995
Well this truck and motor are all brand new. So I was pretty sure it wasn't bearings. I was about to tear it down and check all the diffs, but if it normal, then it's something I have to just tune out. Like you the truck runs fine.
Old 06-16-2014 | 07:25 PM
  #2996
mydudrevo's Avatar
My truck was brand new when it started too. It now still only has 4 days of use on it so I would consider it as still pretty new and it happened straight out of the box. It could be the center shaft rubbing on the battery straps or center brace now that I think about it.
Old 06-17-2014 | 03:13 PM
  #2997
hey guys,
Haha exactly the same whine coming from mine at the same throttle points ... Dunno what this is about either. Newly assembled etc so cant be the bearing and nor the diffs since driving at a constant speed doesnt diff out anything either. I still havent figured out where the whine is coming from but my best guess would be that at that precise throttle the centre dogbone might be movingg back and forth in the drive cups which result in the whine? Just a random guess ... No performance related issue though since it drives perfect. If anyone has another take on this let us all know ..
mamdot91 is offline
Old 06-17-2014 | 05:05 PM
  #2998
Why? Stainless is weaker than you typically want to run on our vehicles, especially with the stress they're under. Stick with the stock screws and if you want some "bulk", these guys in my opinion are best without having to buy them by the hundreds.
http://www.boltdepot.com/
RokleM is offline
Old 06-17-2014 | 05:35 PM
  #2999
ok I was doing some testing on motor temp/esc temp, and trying to figure out the whining sound. I did in-fact find a few things not to my liking on a $600 kit. Do note this is brand new. 1st off I found that my passenger-front drive shaft is warped about 2mm-3mm. This is causing quite a vibration. Possible whine candidate. And before I mention the 2nd issue please do understand I'm not a newbie to building r/c's I have built and flown helis for about 10 years, and been building cars since I was 18.. The center diff gear has a wobble to it. I built it as I do all diffs tightening screws down in a cross pattern a little at a time to keep from warping the plastic. and there is a wobble in the pinion gear also. Put both of them together and there is another possible culprit to the whine. I am disappointed in the drive shaft and the center diff gear, both are warped and came from the factory this way. I am picky and have little to no tolerance for warped parts. LIke the new set of Sweep truggies tires I got the premounted... they are absolutely terrible. Warp'd to high hell and back.. Sweep USA was like oh well sorry to hear that.
This is simply a failure of quality assurance on Tekno's part. Over the years I have found a smaller, new, company always ends up sliding down this road. Greed takes over and quality is surpassed by quantity. Cheaper materials creep in. I hope I'm wrong and Tekno stays on top of their products. Firstly let test there customer service and see if they will replace the warped parts. Hopefully i'm not out the cost of replacing the parts. But nevertheless I still love this truck. And look forward to racing it.
Old 06-17-2014 | 07:00 PM
  #3000
I thought I had read that stainless screws wouldn't be as strong as what comes in most kits but then I read somewhere that it was the opposite.
I just found where I read that.
There is a link to a FAQ on rcscrewz.com where they claim their stainless will be stronger than stock.
I'm not sure what the truth is.
iScream is offline
